Clutch rod
  • wrenchmonkey
  • wrenchmonkey's Avatar
Re: Clutch rod
26 Mar 2016 15:04
#717463
taildragger1197 wrote: Sorry....I couldn't resist. :P
Damn great band. Damn great song. Made ya wanna grab the throttle and twist on.
Let it Hang out now! B)
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: Clutch rod
26 Mar 2016 18:22 - 26 Mar 2016 18:23
#717488
z1kzonly wrote: Ya know when you beat the snot out of these bikes!
I have had the rod weld itself to the stock ball bearing behind the clutch basket and the OEM parts.
Hence the roller bearing fix they sell for the pusher
What does this replace? Do the cases have to be split?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 26 Mar 2016 18:23 by kaw-a-holic.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Clutch rod
26 Mar 2016 18:28
#717490
It goes inside the clutch basket. Never needed one but thought about it. :)
  • KZB2 650
  • KZB2 650's Avatar
Re: Clutch rod
26 Mar 2016 18:35
#717492
You just remove the 5 springs and it replaces the spring plate pusher behind the plate....... Denco stated in their Bonneville bike build it was a absolute must and have read other articles where they really insist on it too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Clutch rod
26 Mar 2016 18:39
#717493
Seems like when I put this in my bike 25 plus years ago I ground a little off the push rod to keep all parrts in spec
  • kaw-a-holic
Re: Clutch rod
26 Mar 2016 20:42
#717513
Seems to me that is correct, I still may have to try one of these, sounds like a quick and easy upgrade.
Street Fighter LTD wrote: Seems like when I put this in my bike 25 plus years ago I ground a little off the push rod to keep all parrts in spec
Jon
1977 KZ1000a1
Mesa, AZ
  • kaw-a-holic
Re: Clutch rod
26 Mar 2016 21:07
#717515
Has anyone used the Easy clutch kit? www.z1enterprises.com/product/PM72-230
Jon
1977 KZ1000a1
Mesa, AZ
  • Moderator
  • Moderator
Re: Clutch rod
27 Mar 2016 05:24
#717535
kaw-a-holic wrote: Has anyone used the Easy clutch kit? www.z1enterprises.com/product/PM72-230
Nope
My next step will be to go hydralic
Dave B) B) B)
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch rod
27 Mar 2016 06:04
#717540
+1
I rally like the Teflon lube, and that little tool is a brilliant invention.
Patton wrote: Neat inexpensive little gadget to quickly force lube throughout length of cable.
Good Fortune! :)
  • kaw-a-holic
Re: Clutch rod
27 Mar 2016 06:14
#717544
Nope
Dave B) B) B)
And I have that figured out for the most part. Still need the 14mm MC. Had a guy sell me one but it turned out to be 5/8 not 14mm. :pinch: All I can find is new 14mm Nissins for a & 150
Jon
1977 KZ1000a1
Mesa, AZ
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Clutch rod
27 Mar 2016 07:24 - 27 Mar 2016 07:25
#717565
I still don't understand why a 5/8 wouldn't work. Not enough throw? I'm going to try the longer actuator arm mod on mine. Just too buisy with other things right now. :whistle:
I wonder if the EZ pull is as temperamental as the stock ones. I remember hearing that dreaded pop on my 350 Honda. PITA. :angry:
Last edit: 27 Mar 2016 07:25 by SWest. Reason: sp
  • kaw-a-holic
Re: Clutch rod
27 Mar 2016 07:51
#717569
swest wrote: I still don't understand why a 5/8 wouldn't work. Not enough throw? I'm going to try the longer actuator arm mod on mine. Just too buisy with other things right now. :whistle:
Correct, not enough throw. I'm to the point now I could have bought the $400 kit from Z1. Pays to do the research.
Jon
1977 KZ1000a1
Mesa, AZ
