First time checking valve clearance
- kzharpe
Re: First time checking valve clearance
22 Feb 2016 07:04
I'll probably just change 3, 6, 7, and 8 then check them again next spring. Now to get the timing fixed and hopefully I can shake loose the kink that's probably in the chain.
1977 KZ650
22 Feb 2016 07:07
If you replace them you'll have the right sizes for a couple of the marginal ones.
- KZB2 650
22 Feb 2016 07:09
While your doing it I wonder if you should do #1 and #5 too getting them up to .006 ....... could save you from doing it again for a good long while...... I did all mine closer to .006 to .007 just for that reason. Don't tighten the cam holder bolts anymore than 70 to 80 "inch lbs" too..... I went 70 to be on the safe side........
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- kzharpe
22 Feb 2016 07:11
Yeah I might as well do those too while I've got it torn apart
1977 KZ650
22 Feb 2016 07:16
I always buy a couple the next size down just to have on hand. I now have the full range for mine.
- kzharpe
13 Mar 2016 15:12
Well I finally got the valves taken care of and the bike is idling a million times better and compression is great now that I threw some mystery oil in the cylinders. I pulled the carbs at some point in the process to do something else and when I put them back on I had zero vacuum on carb 4 and carb 3 was pouring fuel out the overflow. I finally ally gave up and took it to a mechanic today though
1977 KZ650
- Little B
18 Mar 2016 21:57kzharpe wrote: I pulled the carbs at some point in the process to do something else and when I put them back on I had zero vacuum on carb 4 and carb 3 was pouring fuel out the overflow. I finally gave up and took it to a mechanic today though
Nothing wrong with bringing it to someone when you've decided its time. I didn't even want to try messing with carbs so I sent mine to WG. When they come back I shouldn't need to worry about them at all!
1981 KZ750-H2 LTD
- Barry2
18 Mar 2016 22:06
Bear in mind that a good quality fuel filter will go a long way toward preventing overflowing carbs due to a tiny piece of debris caught in a float valve.
1976 KZ900
- car5car
- Banned
19 Mar 2016 04:01Little B wrote:Wrong! They still need to be synchronized! Bench synchronizing is not perfect.kzharpe wrote: When they come back I shouldn't need to worry about them at all!
96 Yamaha Royal Star
82 Yamaha Virago 920
19 Mar 2016 05:10
They will be set up by a pro, not a hack.
- loudhvx
19 Mar 2016 09:13
The crank has 2 to 1 leverage on the cam shaft. And the cam has a lot of leverage at the beginning of movement. So be careful. When it stops, you stop.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- car5car
- Banned
19 Mar 2016 10:45So you saying bench synchronizing is perfect if done right and bike adjustment is not needed?swest wrote: They will be set up by a pro, not a hack.
Holding wire under slide doesn't seem like very complicated job to me.
