First time checking valve clearance
  • kzharpe
  • kzharpe's Avatar Topic Author
Re: First time checking valve clearance
19 Mar 2016 17:07
#716230
650ed wrote: Still no model in signature line? Why?
Thought i changed it the other day on my phone. Guess it didnt take. Should be there now
1977 KZ650
19 Mar 2016 17:23
#716233
Yes; it's there now. Thanks!
Regarding the noise you hear at low rpm - how low are the rpm when you hear it? The KZ650 engine can make some rather nasty sounds if the rpm are below normal idle setting which is 950 - 1050 rpm. Also, if the carbs are not properly sync'ed (not just bench sync'ed) you can can noises deep in the engine at idle rpm. I believe both the low rpm and carb sync noises both come from the primary chain area. Ed
  • kzharpe
19 Mar 2016 17:49
#716236
It makes the noise all the way up to about 2k then starts to quiet down
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Mar 2016 18:01
#716237
Have you adjusted your cam chain?
  • kzharpe
19 Mar 2016 18:17
#716241
I have reset the timing since I accidentally dropped the chain while doing the valves. I'm not sure mine is adjustable? If so, how do I go about doing it
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Mar 2016 18:27
#716244
Do you have a manual?
  • kzharpe
19 Mar 2016 18:28
#716245
Yeah. I don't recall seeing seeing anything about adjusting the timing chain but I'll look
1977 KZ650
19 Mar 2016 19:00
#716247
The cam chain itself is not adjusted, but the 1977 KZ650 engines have a manual cam chain tensioner that should periodically be adjusted. Do NOT fiddle with it though unless you have the service manual in front of you, because when adjusting it you MUST FIRST turn the crankshaft to a specific position or you will makes things much worse. Adjusting it is easy to do, but impossible without the instructions. Ed
  • kzharpe
19 Mar 2016 20:00
#716264
Think I found it
1977 KZ650
  • kzharpe
20 Mar 2016 03:03
#716286
Sorry I don't think that picture posted. It sounds similar to the procedure for finding top dead center
Attachment Screenshot_2016-03-19-21-58-54-1.png not found
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Mar 2016 05:07
#716288
If adjusting it doesn't quiet it down then opening it up and looking at the guides is in order,
