Oil for break-in after top end rebuild 1982 GPz750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil for break-in after top end rebuild 1982 GPz750
01 Jan 2016 16:21
#705225
OR wants $25 a gallon and AZ gets $17. Guess I'm going to WM.
  • zukdave
  • zukdave's Avatar
02 Jan 2016 04:22
#705250
When I did my motor I fired it up on Rotella 15-40 ran it long enough for
it to idle no choke then did a drain and fill then put a fan on ran about 10 min.
and did a oil and filter change then went and did a few WFO blasted down the street
and changed it again.
I do change my oil every time I go to the track so lets see about 25 mile's on it and the
next oil change will be number eight
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • bluej58
  • bluej58's Avatar
02 Jan 2016 04:32 - 02 Jan 2016 04:32
#705252
Rotella 15W-40 for diesel engines
78 KZ1000 A2A
Last edit: 02 Jan 2016 04:32 by bluej58.
  • Nessism
  • Nessism's Avatar
02 Jan 2016 05:27
#705259
zukdave wrote: When I did my motor I fired it up on Rotella 15-40 ran it long enough for
Hey man, there is this thing called an OIL FILTER in the system which removes particulate matter down to the low single digit micron level. Not that recycling oil is bad mind you, some container ship is probably very happy with the quality of your discarded oil. :P
  • woodman
  • woodman's Avatar
02 Jan 2016 08:03
#705286
I think the deal with using synthetic oil in a new engine is that its ok as long as you have the proper rings, clearances and cylinder wall finish but the stock pistons & rings wont seal unless you have all of the above. Just my opinion, I use the Rotella also
  • zukdave
  • zukdave's Avatar
03 Jan 2016 13:37
#705453
Nessism being I drag race mine I change it that offen to rinse the clutch
fiber out of the motor. I go with nice new oil and when I get home the oils
black from sliding the clutch.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • kawi810
  • kawi810's Avatar
03 Jan 2016 14:36
#705456
most guys do not drag race there motors if they did they would dump the oil after a few pases .the heat from the clutch is a enough to break down the oil.i would just to make sure my clutch would lock up.new oil is cheap.
es
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • Tyrell Corp
  • Tyrell Corp's Avatar
03 Jan 2016 15:02 - 03 Jan 2016 15:05
#705457
This is an interesting topic, ring break-in is critical and there are differing opinions.
I have an old Wiseco XC GPz615 piston kit and the rings are NLA - there was a thread on this subject a few years ago and the same used pistons were later gifted to me by a member here (thanks Corey)
Ring gaps are all within spec, I asked total seal about it - presumably these guys know piston rings, and their recommendation was, in the absence of a new ring set they can't supply, to use their dry break-in lubricant powder and a non synthetic oil initially. This motor is still on the bench but I will report back in due course.
Edit: those 82 GPz750 twin shock are very good, strong motors and great handling, enjoy!
Last edit: 03 Jan 2016 15:05 by Tyrell Corp.
  • Nessism
  • Nessism's Avatar
03 Jan 2016 18:30
#705491
Tyrell Corp wrote: This is an interesting topic, ring break-in is critical and there are differing opinions.
Any idea what's in this "dry break-in lubricant powder". What's the premise for it's use? Is there grit in it to assist the rings in seating?
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jan 2016 18:32
#705492
Good question.
  • TexasKZ
  • TexasKZ's Avatar
03 Jan 2016 19:48 - 03 Jan 2016 19:51
#705499
A graphite or Teflon lubricant, maybe? I would be fairly terrified to put any sort of grit in an engine. As soon as it starts, that stuff would be everywhere the oil goes. Cams. Bearings. Oil pump. :blink:
Last edit: 03 Jan 2016 19:51 by TexasKZ.
  • Tyrell Corp
04 Jan 2016 10:22
#705540
Attachment download-2.jpg not found
It is a tiny tub with about 1 gram in, you rub it on the bores and they have a greenish tint - I suspect some sort of Teflon?
I did some googling on it and there are some good reviews. I think the idea being to lubricate without an oil film, for the critical first few minutes of running.
The following user(s) said Thank You: NHenneous
