- Thank you received: 8
Oil for break-in after top end rebuild 1982 GPz750
- Madtrout
- Thank you received: 2749
- Thank you received: 2823
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Madtrout
- bountyhunter
- Thank you received: 337
Same thing I did except I added some STP to juice up the ZDDP content during break in. I think I used 10-40 Valvoline.swest wrote: I'd use cheap store brand oil. 10-40/5-30. Dump it after 500 miles.
- bountyhunter
I have read that a bunch of places. But I never saw any actual data to support it and the oil makers say it's baloney. I would never use synthetic for break in because I am too cheap to put in $40 worth of oil I am going to dump after 100 miles.ThatGPzGuy wrote: I've always heard to never use synthetic oil to break in an engine. The rings will take much longer to seat..
- Thank you received: 2234
What I find puzzling is guys who will spend hundreds or thousands of dollars on an engine rebuild in their most prized possession and then fill it with the cheapest oil available during the most critical moments of the engine's life.
- Madtrout
- redhawk4
- Thank you received: 64
The ZDDP is needed mostly for cam break in with solid lifters and also needed for normal running with solid lifters. The only thing to watch using a cheaper oil is if it's a car oil they can contain additives that can damage your clutch plates. Rotella is the best bang for your buck IMO, about $13 for a gallon and is often used as a break in oil because of the ZDDP and is also JASO approved which means it's OK for a wet clutch. The high detergent content of diesel engine oils are also good for keeping any contamination, following a rebuild, in suspension so it comes out when you change the oil.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
