Cam cap bolts stripped
Re: Cam cap bolts stripped
27 Dec 2015 10:22
When doing one (or 16 as it were) of these thread repairs be very careful to drill and tap the hole straight. If the head is off the bike using a drill press can help. It's quite easy to install the insert crooked so please take your time.
The following user(s) said Thank You: PLUMMEN
- DFIGPZ
27 Dec 2015 11:12Larry don't forget to mention the idiots that should not ever have a wrench in hand ! :evil:LarryC wrote: See this all the time..... Just had to repair all 16 holes in a head. All got helicoils. You can't easily use time-certs on cam tower bolt holes. Helicoils are much easier for that application and will suffice.
Have had heads come in with broken off drill bits and broke off taps in the same hole. Those are always fun.
It's always the 4 bolt caps you see this with. Rarely do you see a 2 bolt cap with stripped out holes. THAT ought to tell you that dowel pins located on opposing corners of a 4 bolt cap require a little bit of attention when installing the caps. The problem that causes this is almost always binding on the dowel pins because of improper tightening and not paying attention to checking the pins for burrs, the cap for burrs and making sure the pin is in the head with the tapered end up.....and last but not least.... apply some oil to the dowel pins, the caps and the bolt threads.
As long as these motors are around there will be stripped cam tower bolt holes. That's as certain as the sun rising in the east.
1984 750 Turbo
- Kz_Café
28 Dec 2015 05:51
So I went with the helicoils. A previous contributor pointed out there's a special tap timeserts use to get the insert below the bolting surface and it doesn't seem to work for this application.
I think I saw someone mention using locktite to secure the coil in place, any opinions? I've got about a week and a half to think about it with my thumb up my bum. I guess I'll continue degreasing and other bits of maintinence from my factory service manual.
I'll be sure to post pictures and such on how it went and how I feel about the product.
Cheers!
Cheers!
1982 KZ550 LTD: Mechanicaly stock, Unknown milage.
- Kz_Café
28 Dec 2015 05:54DFIGPZ wrote:Larry don't forget to mention the idiots that should not ever have a wrench in hand ! :evil:LarryC wrote: See this all the time..... Just had to repair all 16 holes in a head. All got helicoils. You can't easily use time-certs on cam tower bolt holes. Helicoils are much easier for that application and will suffice.
Let's not forget that good judgement is learned from bad judgement, and sometimes bad judgement is catestrophic, and that shouldn't stop us from mentoring the ignorant.
28 Dec 2015 07:28
Ignorance is treatable. There's no cure for stupid. :lol:
- zed1015
28 Dec 2015 08:27Kz_Café wrote: I think I saw someone mention using locktite to secure the coil in place, any opinions? .
Cheers!
Don't bother with Loctite as it is "Anaerobic" which means it only cures in the ABSENCE of air and therefore not suitable with the inserts open coil design.
The locking action of the insert expanding once installed is sufficient.
Do not use Loctite on a Helicoil/Wire coiled insert repaired hole as the Loctite can bond the insert to the bolt which can then lead to the insert winding out with the bolt on removal at a later date.
The following user(s) said Thank You: Kz_Café
- Old Man Rock
28 Dec 2015 10:39
I followed these instructions and have had no issue in doing so....
Helicoil Instructions/procedure
Rather than just relying on the HeliCoil spring tension to retain the insert, is there any way to positively lock the insert into the housing threads?
The following methods are recommended to help secure an insert into the housing...
Apply a light coating of Loctite Thread-Locker compound to the external portion of the coils of the insert prior to threading it into the housing. If this method is used, be sure not to apply too much Loctite and be sure to wipe the internal threads of the HeliCoil insert clean after it is installed so that the fastener does not bond to the insert.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Kz_Café
29 Dec 2015 06:21
Interesting, I see both sides of the coin. Kinda seems like risky business applying locktite to the coil, how about a light coating in the outer thread the coil inserts to. Seems like a viable option to mitigate any excess thread locker getting on the bolt and binding everything up.
29 Dec 2015 06:37
I haven't needed it and never had one come out.
- baldy110
29 Dec 2015 08:13
I have installed dozens of helicoils in cam cap bolt holes, never had any that came back out and I installed all of them dry.
- loudhvx
29 Dec 2015 10:35 - 29 Dec 2015 10:40
I would also vote dry. Imagine the headache if some Loctite ends up on the bolt. Loctite can stay liquid a long time in open air.
BTW, 550's have all two-bolt caps. No four-bolt caps.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Dec 2015 10:40 by loudhvx.
- KZB2 650
29 Dec 2015 11:25
Had 2 I trust outta 4 say to use it and 2 not......... Jay from APE was the 5th and deciding vote with another no on the locktite. (After driving 50 miles for a high temp special red too). :S
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
