Cam cap bolts stripped
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Cam cap bolts stripped
29 Dec 2015 11:37
#704788
Holly Crap you guys kill me for always a debate with you.... :laugh:
Never said you had to or if it was the preferred method...
I followed the instruction, let it dry then inserted the cap bolts once fully dried.
Only sated what I used resulting in no problems on stuck cap bolts.
This place never changes does it.... :laugh: :laugh: :laugh: :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
29 Dec 2015 11:38
#704790
Old Man Rock wrote: ............
OMR
Nope. :laugh: :laugh: :laugh: Ed
  • LarryC
  • LarryC's Avatar
29 Dec 2015 15:15
#704819
Some wipe up....some wipe down.....and some don't wipe at all.... those are the ones you ignore :side:
Larry C.
The following user(s) said Thank You: Kz_Café
  • LarryC
  • LarryC's Avatar
31 Dec 2015 13:39
#705065
From the manufacturer....
Rather than just relying on the HeliCoil spring tension to retain the insert, is there any way to positively lock the insert into the housing threads?
The following methods are recommended to help secure an insert into the housing...
Apply a light coating of Loctite Thread-Locker compound to the external portion of the coils of the insert prior to threading it into the housing. If this method is used, be sure not to apply too much Loctite and be sure to wipe the internal threads of the HeliCoil insert clean after it is installed so that the fastener does not bond to the insert.
HeliCoil Install
This is simply another one of those commons sense deals. That is to say somewhere out there would be someone that would apply way too much threadlock and not bother to clean out the excess. There's absolutely nothing wrong with using threadlock on helicoil, providing you've got common sense. I swear, 98% of the problems I see posted in forums that go page after page in explanations all stem from lack of common sense....
Larry C.
The following user(s) said Thank You: PLUMMEN
