1981 KZ440 won't start, timing problem?
- Benny77
Re: 1981 KZ440 won't start, timing problem?
22 Dec 2015 21:16
Thanks!!!! I removed the leads and checked directly on the back of the coil and still no reading. definitely a bad coil. I found a used bike parts place here in Portland called Cycleheap that is parting out a running kz440 that had an engine knock. I'm getting the stock factory coil for $37. also a couple of other bits and pieces I need.
Thanks for all your help guys!!!! I'll keep you posted on how it goes...........
- missionkz
22 Dec 2015 23:36 - 22 Dec 2015 23:37
Personally, I would greatly hesitate to buy a 34 year old coil.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 22 Dec 2015 23:37 by missionkz.
23 Dec 2015 03:14 - 23 Dec 2015 03:21
I would go ahead & get a new coil. When getting used, you might could try a late model 1000P Police bike or maybe a coil from a 2002 or so ZR7 --- at least a coil from one of those wouldn't be so ancient, although 10-15 yrs old is getting there. assuming it has electronic ignition.
Timing Advancer. Also, be sure to clean, check & lubricate the timing advancer. separate the rotor from the body for servicing. make sure the springs are good & that it snaps back after actuating it. I use high temp wheel bearing grease.
Last edit: 23 Dec 2015 03:21 by martin_csr.
- Benny77
26 Dec 2015 11:04
Thanks for all the help guys.
I just went out and bought a compression tester from Harbor Freight. I screwed the hose directly into the spark plug hole (didn't use the adapter) and got 90 lbs compression in the right cylinder, and 100 lbs of compression in the left cylinder. Manual says the lowest serviceable limit is 107lbs. It appears my engine needs a rebuild.
26 Dec 2015 12:14
The engine was at full operating temperature (hot), and throttle was wide open?
26 Dec 2015 12:18
WAIT! The readings you got may be wrong!
In order to properly test the compression the following must be done:
1. The engine MUST be up to the normal operating temperature, This is because the pistons are tapered. When the pistons are at the proper hot temperature they expand near their tops and this enables the rings to seal properly against the cylinder walls.
2. The battery must be fully charged so it turns the engine over quickly.
3. All spark plugs must be removed so the engine turns over quickly.
4. The throttle needs to be held wide open during the test.
If these conditions were not met during the test you performed your readings will be low even though your compression may be perfectly fine. Ed
- Benny77
26 Dec 2015 12:42
thanks guys!!! I've been sitting here waiting for somebody who knows what's up to reply.
My battery was fully charged
spark plugs are removed
I DID NOT have the throttle wide open.
The engine doesn't run, so there is no way to get it up to temp before doing the test.
I'm gonna go do another compression test with the throttle wide open and report back.
- Benny77
26 Dec 2015 12:54
2nd test results:
engine COLD
battery fully charged
throttle wide open
spark plugs removed
90 psi on right side
100 PSI on left.
What do you guys think?
engine COLD
throttle wide open
spark plugs removed
100 PSI on left.
26 Dec 2015 13:26
I think I would try it again with the engine warmed up. If that is not possible then I would do a leak down test. In any case I would certainly do a leak down test before disassembling the engine since that will tell you where you are loosing compression (if you are loosing compression) . Ed
- bountyhunter
26 Dec 2015 14:45650ed wrote: WAIT! The readings you got may be wrong!
+1 I would also check to make sure the head bolts were torqued down to spec.
- bountyhunter
26 Dec 2015 14:48 - 26 Dec 2015 14:52Benny77 wrote: 2nd test results:
engine COLD
throttle wide open
spark plugs removed
100 PSI on left.
Leak down test is best if you can do it.
Another test is to squirt a little oil in the cylinder and repeat the compression test. It the reading comes up significantly (like 20 points or more) it usually means that the rings are not sealing well.
If you do NOT see a big change in compression, it probably means the loss is due to valves not seating well.
If valve clearances are correct, then it probably means you need a valve job.
Last edit: 26 Dec 2015 14:52 by bountyhunter.
26 Dec 2015 19:36
A leak down test is more informative for sure. However, on an engine that has not run in 8 years, even a leak down test may be misleading since the rings may be stuck and not properly sealing. Surely even 90psi is enough to start with.
Seems to me that it would be best to check valve clearances to be sure none of them are way off, run the engine enough to loosen the rings and then continue testing.
