1981 KZ440 won't start, timing problem?
- Benny77
Re: 1981 KZ440 won't start, timing problem?
28 Dec 2015 08:57
I will check the ignition box and clean it up tonight and report back!!!
- rrsmsw9999
28 Dec 2015 09:27
Also check on the orientation of the iron rotor. It may not matter for a twin, but on my 550 it was 180 degrees off and the bike wouldn't make so much as a peep, even with spark and compression. Good luck. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- bountyhunter
28 Dec 2015 11:25same on my 750 twin. get it on 180 off and it won't even fire.rrsmsw9999 wrote: Also check on the orientation of the iron rotor. It may not matter for a twin, but on my 550 it was 180 degrees off and the bike wouldn't make so much as a peep, even with spark and compression. Good luck. R
- Hexadecimus
07 Aug 2016 21:09
What did it turn out to be? I have a 440 that will not start no matter what I do. 150/143 psi cold, blue spark, getting fuel, valves seating well at TDC. Still won't fire.
