1981 KZ440 won't start, timing problem?
  • Benny77
  • Benny77's Avatar Topic Author
Re: 1981 KZ440 won't start, timing problem?
26 Dec 2015 20:17
#704471
I adjusted the valve clearances to spec as per the FSM, there were a couple that were tight, they are all within spec now.
  • DGA
  • DGA's Avatar
26 Dec 2015 20:21
#704472
Maybe I missed where you checked the cam timing? Valve timing a tooth off will give low compression readings.
My 1100 Spectre would not run on all cylinders when I got it, ONE of the many problems was a set of new coils and one of those coils had a dead output.
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
  • Benny77
26 Dec 2015 20:54
#704477
Checking the cam timing is my next move....... I've been trying to avoid taking the top of the engine apart if at all possible.
  • Benny77
27 Dec 2015 10:11 - 27 Dec 2015 10:13
#704539
So, I took the rocker cover off to check the timing, and everything appears to be good as per the factory service manual. the arrow is lined up with the surface the rocker cover mates to, the mechanical advance timing mark "T" is on the timing mark and the piston is at top dead center. Anything I'm missing here?
s1121.photobucket.com/user/Benny775/medi....jpg.html?sort=6&o=4
i1121.photobucket.com/albums/l505/Benny775/2_zpsogz9fgqf.jpg
i1121.photobucket.com/albums/l505/Benny775/3_zpsmsp9nd6w.jpg
Last edit: 27 Dec 2015 10:13 by Benny77.
  • Benny77
27 Dec 2015 10:16
#704541
in case the photobucket links don't work.......
  • Benny77
27 Dec 2015 13:26
#704570
I'm thinking it's got to be an electrical problem? or maybe the compression is too low and the engine needs a rebuild? what do you guys think?
27 Dec 2015 14:57
#704574
I definitely would check out everything at least twice before contemplating a rebuild. Problem could easily be electrical, ignition system, fuel delivery, etc., etc. Ed
  • rrsmsw9999
  • rrsmsw9999's Avatar
27 Dec 2015 18:18
#704591
Wouldn't effect starting but that advancer needs lube and attention. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Benny77
28 Dec 2015 08:09
#704626
performed a cylinder leak down test. both cylinders are only losing about 10%. So, these results would indicate that the engine is good, really good................ now I'm really confused.
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
28 Dec 2015 08:45
#704629
I would work toward getting it running before anything else. Doing a compression check on a cold motor that hasn't run in 8 years isn't really fair. I think your numbers are promising and would do the comprssion test in more favorable conditions.
Blue 1975 Z1B
Red 2009 Concours 14
  • rrsmsw9999
28 Dec 2015 08:54
#704630
Looking at the ignition box again it also looks like the electrode on the magnet is badly corroded too. That would effect starting and running. I'd clean it up lightly with emery cloth and clean and lube the advancer before trying to run it again. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Benny77
28 Dec 2015 08:55
#704631
I'm doing the test's to try to figure out why it won't start. it has spark, the timing is correct as per the FSM, it appears to have compression and the cylinders don't seem to be leaking down any air. the bike won't fire AT ALL. even if I squirt gas directly into the cylinders. The carbs have been cleaned out TWICE. All I can think is, even thought I have pretty blue spark, it's still not hot enough, and is getting blown out under compression.
