'82 GPz750 Exhaust replacement options?
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
Re: '82 GPz750 Exhaust replacement options?
06 Sep 2015 09:39
#688867
swest wrote: Pic?
At the moment...
  • GPzMOD750
06 Sep 2015 16:30 - 06 Sep 2015 17:10
#688907
Ok I got the header on.
I had to push the oil cooler lines back just a bit as they were pushing right up on the crossover.
I had to take off the center stand which is something I was hoping wouldn't be the case. I guess I'll have to get a paddock stand.
I haven't found a suitable clamp yet. I was close but it wasn't quite small enough. I am using aluminum muffler repair tape as a gasket which actually seems to work well. I'll have to rig up some hangers too.
Last edit: 06 Sep 2015 17:10 by GPzMOD750.
  • GPzMOD750
Re: Re:'82 GPz750 Exhaust replacement options?
07 Sep 2015 15:08 - 07 Sep 2015 15:09
#689047
I think I've figured out hangers. The stock right hanger was cracked pretty bad. It looks like it had been repaired once but had cracked again parallel to the repair.
I swapped the left hanger to the right and it's positioned perfectly so I can run a 1/8x3/4" piece of aluminum strap with a half twist up to the Kerker mounting point.
I should be able to run another piece of strapping from the motor mount bolt just ahead of the foot peg down to the exhaust clamp.
Last edit: 07 Sep 2015 15:09 by GPzMOD750.
  • GPzMOD750
Re: Re:Re:'82 GPz750 Exhaust replacement options?
07 Sep 2015 16:38
#689061
GPzMOD750 wrote: ...
Scratch this. I realized that bolt runs straight through the crank case. I don't want to mess with that. Maybe I'll just use some sort of spring set up off a different point. I have some old drum brake springs scattered around.
  • GPzMOD750
09 Sep 2015 06:02 - 09 Sep 2015 06:03
#689305
Mounting done! I hope.
It's very solid so I'm thinking I won't have to put a hanger at the collector. Found the clamp at Napa, super solid fit. O'Reilly's had the same clamp for nearly half the price but would have taken nearly a week to get in.
I can't decide if the hanger looks ghetto or not. It fits like a glove especially considering the haphazard method of measuring and fitting the thing, probably used up all my luck for the rest of the year.
Last edit: 09 Sep 2015 06:03 by GPzMOD750.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2015 06:04
#689306
Pics?
  • GPzMOD750
09 Sep 2015 06:14
#689308
swest wrote: Pics?
it's there, didn't take on the first upload.
I guess I should be fairly pleased considering I'm barely over $100 for the whole setup.
  • GPzMOD750
12 Sep 2015 15:19
#689794
I put it together and it sounds awesome, It isn't loud like i expected, actually not as loud as before. It sounds more like a performance quad than a beat up bike with leaky exhaust. I did get some popping on down shift and deceleration. I'll adjust the carbs tomorrow and if that doesn't help I'll re-jet and see how that goes.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Sep 2015 18:08
#689808
Look at your plugs. :)
  • GPzMOD750
13 Sep 2015 21:01
#689955
swest wrote: Look at your plugs. :)
I will.
I adjusted all the primary jets out a turn and re-balanced the carbs and it's running much better. Gets up a goes like they are giving out cash prizes at the destination. :P
No popping just a hint of a putt-putt when closing the throttle. More of a sport bike buzz tone than a leaky pipe grumble.
  • Tyrell Corp
  • Tyrell Corp's Avatar
14 Sep 2015 04:30
#689980
It would be nice if you could just angle the tailpipe up a bit, also increase ground clearance.
That rear clamp isn't up to it, if you drill the rivets out of the can you can work from inside and move the rear hanger mount further back a bit.
IMO a bit of popping on the overrun is no big deal, as you noticed you can tune the worst of it out on the pilot airscrews
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Sep 2015 04:57
#689986
I was thinking that too. They're just pop rivets. You could drill the heads, move the muffler to 90* and reattach the end with pop rivets and use a flat bracket.
