Kz750 E. Ignition Timing is not right.
  • matigipler
  • matigipler's Avatar Topic Author
Re: Kz750 E. Ignition Timing is not right.
24 Jul 2015 11:13
#682525
so after i rebuilt it it wouldnt start ( just now) i fliped the cam 180 degrees and it started like before. not alinged with the TEC mar what so ever......
does this make any sense????
  • matigipler
24 Jul 2015 11:21
#682528
I did the same thing and in my case when the advancer cam points at the same coil it is marked at the T mark not F....... not sure why or what would cause it to do this since engine timing is individual from this. yes the advancer only goes in one way. im at a loss not sure what the hell to do other than drill slots and advance it.
ALso my timing advanver has a 005 yours says 1013 on it. which makes me wonder if it was ever replaced by the previous owner. maybe its not the right one????? im gona take some pictures.
  • matigipler
24 Jul 2015 11:39 - 24 Jul 2015 11:43
#682532
here is when the cam aligns with the coils
am i crazy?
the bike itself dosent want to rev under load. like no power what so ever.
also i notice how my advancer looks different the cam is not the same degree with the marks, the weights looks sort of different as they dont have that lip at the end. end the plat says 005. maybe someone changed the advancer a while back??
Last edit: 24 Jul 2015 11:43 by matigipler.
  • baldy110
  • baldy110's Avatar
24 Jul 2015 12:25
#682535
Someone might have swapped out a the advance assembly from another engine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2015 12:29
#682537
You might be better off with a Dyna S.
  • JR
  • JR's Avatar
24 Jul 2015 12:50 - 24 Jul 2015 12:51
#682542
All very strange. Your advancer looks a lot different to mine. I checked parts diagrams for 1980 KZ750 E1 and the advancer is part # 21148-1013 so I have the correct one and I have to agree that it looks like the PO swapped yours out for the 005
I also put part # 21148-005 into a few dealer websites and that is a part # for an advancer but I cant find for what. I might be able to find out tomorrow - (long story)- and which still wont make it work.
Steve may have the answer
Last edit: 24 Jul 2015 12:51 by JR.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2015 13:53
#682550
The old electronic units can have problems. I wouldn't waste money on it when a Dyna S would fit.
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
24 Jul 2015 13:57
#682552
If you are timed at the T mark your timing is retarded and would explain sluggish performance.
1982 Kawasaki KZ550 LTD
  • KZB2 650
  • KZB2 650's Avatar
24 Jul 2015 14:01 - 24 Jul 2015 14:10
#682553
Wrong advancer.
Patton commented on this 7 years 11 months ago on a thread called Dyna S timing .......... google the part number and it came up something to do about a 1974 - 1975 900 advancer that has 5 degree's of advance instead of 20 degree's........ Lodhvx was on it too. Will try to read more on it or check it out guys.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 24 Jul 2015 14:10 by KZB2 650.
  • KZB2 650
  • KZB2 650's Avatar
24 Jul 2015 14:09
#682554
Ok search the number 21148-005 advancer on here and the thread comes up.
1978 KZ650 b-2
  • matigipler
24 Jul 2015 15:54
#682559
If i just change to a Dyna S ignition will it solve my issue or do i still need to buy a 1013 advancer??????
  • matigipler
24 Jul 2015 16:17
#682563
Also i set the timing initialy with this advancer. does that mean my engine timing is off given its the wrong one.?????
