Backfiring 82 KZ1100. Won't start.
  • eric951turbo
  • eric951turbo's Avatar Topic Author
12 Jul 2015 08:54 - 14 Jul 2015 20:10
#680516
Kz1100 a2 shaft 1982.
I did a cafe racer out of it all winter. I'm done, no start.
- took engine out, adjusted valves, all within specs
- simplified and rewire everything (no more lockout switch for example)... I followed instructions on www.bikeexif.com/motorcycle-wiring
- bike is turning, had to change starter clutch, sprocket and starter
- I have spark on all 4 spark plugs
- fuel in carbs
- checked compression: #1: 155psi #2 150 #3 150 #4 155
Everything seems in specs, while its turning, the bike will backfire, with flames coming out the tail pipes.
I'm completely out of ideas, please help
Last edit: 14 Jul 2015 20:10 by KZQ.
  • TexasKZ
  • TexasKZ's Avatar
Re: Backfiring 82 KZ1100. Won't start.
12 Jul 2015 12:16 - 14 Jul 2015 20:10
#680531
Spark plug wires hooked up wrong? One coil fires cylinders 1 an4, the other one fires 2 and 3.
Coils wired backwards? That is, is the left coil getting the right coil signal, and vice versa?
  • eric951turbo
12 Jul 2015 12:30 - 14 Jul 2015 20:10
#680536
Tks for the reply, I'm currently finishing cleaning my carbs, but I went to check the coils wiring. Does it make a difference if I switch blue and red wires on one left side coil? I'll be able to test in about 1/2 hours after I reinstall carbs
  • eric951turbo
12 Jul 2015 13:18 - 14 Jul 2015 20:10
#680555
So I cleaned my carbs, checked ignition wiring, still nothing... Just cranks and cranks and 'pow' pow exhaust and fumes coming out my air filter pods.
Any more help would be apreciated
  • eric951turbo
12 Jul 2015 14:23 - 14 Jul 2015 20:11
#680565
New update, checked timing and valve clearance, everything is dead on. Still no start. I can see flames and fire in my pod filters when I crank and it pops
Last edit: 14 Jul 2015 20:11 by KZQ.
  • eric951turbo
12 Jul 2015 17:37 - 14 Jul 2015 20:11
#680591
new update: I installed some cheap emgo pod filters while putting the bike togheter, now I found a thread about the inside of the pod blocking all the carbs air ports. now that they are off, my battery is totally drained and the engine flooded.. so i can't test without filters until tomorrow.
question is, could blocking all the vent ports on the carbs create a 'no start' issue????
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
12 Jul 2015 19:48 - 14 Jul 2015 20:11
#680617
Your advancer isn't 180 out is it?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
  • eric951turbo
13 Jul 2015 06:25 - 14 Jul 2015 20:11
#680669
If it was, my wires would be facing up, no?
  • KZB2 650
  • KZB2 650's Avatar
13 Jul 2015 08:37 - 14 Jul 2015 20:12
#680687
No he's talking about the advancer behind the points plate ...... did you remove it to clean and grease it ? If not it won't be it.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 14 Jul 2015 20:12 by KZQ.
  • eric951turbo
13 Jul 2015 08:47 - 14 Jul 2015 20:12
#680689
I recall removing the ignition plate for better seeing the timing marks when i adjusted the valves clearance. Bu t I dont recall messing around with the advancer itself...
but now, after looking at this thread, i found something... since i started messing with the bike, I've been rotating the engine using the 12mm bolt, not the 17mm.
maybe something is off, I'll take a look tonight.
havent been easy since the bike was put togheter,
1. I burnt the starter, replaced with a cb900 starter
2. Burnt the starter clutch, replace springs and other round metal things, didn't worked, had to find a new starter clutch and sproket (mine had scratches).
3. pulling the magneto rotor to replace starter clutch, I droped it on the floor, the magnet inside broke.
4. So I finally bought a KZ1000 for 350$, not possible to put on the road (previous owner didn't pay tickets), so now I have lots of parts.
everthing replaced, not I can't start the bike. can't wait to check the advancer tonight.
thanks
  • eric951turbo
13 Jul 2015 16:56 - 14 Jul 2015 20:13
#680740
HELP. Decided to start a new post because of the progress. KZ1100 a2 shaft. NO START. Backfires when cranking.
After checking :
- fuel in carbs
- advancer timing mechanic is ok(not 180 degree impossible on my bike)
- compression is good on all cylinders)
- spark on all plugs
- engine timing is dead on
- valve clearance is dead on
- I redid all the wiring, I must of checked 10 times each single wire
- spark plugs leads are connected the right way
- cleaned my carbs yesterday
NOW, I noticed that when I'm cranking without plug #2, it doesn't backfires / pops
If #2 is plug, cranking without air filters, carb #2 is popping, shooting out fuel
Where can I look now?
Last edit: 14 Jul 2015 20:13 by KZQ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Jul 2015 18:58 - 14 Jul 2015 20:14
#680752
Switch the two wires coming from the points.
Last edit: 14 Jul 2015 20:14 by KZQ.
