Backfiring 82 KZ1100. Won't start.
  • eric951turbo
  • eric951turbo's Avatar Topic Author
Re: Backfiring 82 KZ1100. Won't start.
16 Jul 2015 05:51
#681098
only cleaned them, and they where already clean from last fall. I'm waiting for larger main and pilot jets for Z1E.
no idea what the thumb test is, ill check it out on google.
but do i feel stupid, went in the garage last night and realized that there was not more fuel left in the tank with all those emptying carbs bowls and tests. havent had a chance to try to start it, will try tonight.
  • eric951turbo
16 Jul 2015 05:53
#681099
ah, thumb test is for compression. I have a compression tester. my compression is #1: 155, #2: 150 #3: 150 #4: 155
so the compression is more than good. and the numbers didn't change since last fall before I dissembled everything.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jul 2015 06:46
#681103
No, you lift the slides with your finger, put your thumb over the large vent on the top beck of the carb, let the slide go and see if it stays or falls quickly. I was thinking if the diaphragms are shot, it might do it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jul 2015 06:48
#681104
I know they cost a lot but the bike won't run with bad ones.
  • rrsmsw9999
  • rrsmsw9999's Avatar
16 Jul 2015 07:03
#681109
My $0.02. Invariably the symptoms you state popping, flames and backfire through carb is almost always a severe intake leak. Perhaps you have pinched a hole in your new rubber tubes. Also if you do not have a the carbe bank mounted fully (I know form exp) massive air leaks occur and do what yours does. . Secondarily I go with torn or mismounted diaphragms next. This also causes air leaks and more of the popping decel poor performance variety issues. You are not far off it's something obvious, but insidious :evil:
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • eric951turbo
03 Aug 2015 10:19
#684064
thanks guys, I found the problem. I switched the ignitor / timing advancer with the one on my part bike and all is back to normal.
