Slipping clutch
- bb41077
Re: Slipping clutch
04 Jun 2015 15:57
Sitting since 96, I had to put a starter clutch in. It did move real good for about 2 days then it slipped, has 37,XXX miles on it
Bruce Bakken
- bb41077
Re: Slipping clutch
04 Jun 2015 16:00
Seems like I always have gas in my oil, I've changed it about 3 or 4 times since I got it running again to flush out the motor. And changed oil filter couple times. I've maybe put 25 miles on it.
Bruce Bakken
- bb41077
Re: Slipping clutch
04 Jun 2015 16:01
And the clutch handle is tight. Probably to tight huh
Bruce Bakken
- spdygon
Re: Slipping clutch
04 Jun 2015 16:39
U need to fix the carbs leakage. Gas in the oil will break it up...o would say that is what causing the clutch to slip.
Lever should have about 1/4" play.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- bb41077
Re: Slipping clutch
04 Jun 2015 16:47
Ya I do got one carb leaking, I've almost got it right but the rubber diaphragm on top of the carb ripped a little.
Bruce Bakken
Re: Slipping clutch
04 Jun 2015 18:10 - 04 Jun 2015 18:12
The clutch plates may be fine. The clutch cable may be so far out of adjustment that it is preventing the clutch from fully engaging. The cable may be so dry that it is hanging up. The release mechanism may be gunked up.
Get out yor factory service manual and carefully clean and service the clutch lever, cable and release mechanism before declaring the clutch dead.
Oh, and fix the petcock and carbs. A sump full of gasoline can cause catastrophic damage.
Last edit: 04 Jun 2015 18:12 by TexasKZ.
Re: Slipping clutch
04 Jun 2015 18:26
When the clutch plates sit for a long time, they become stuck together. Taking them out, cleaning them and putting them back in oiled could solve the problem. A stuck actuator could cause this too.
The following user(s) said Thank You: bb41077
- bb41077
Re: Slipping clutch
04 Jun 2015 20:09
U guys r all awesome I put everything back together adjusted the cable and changed the oils again and took it for a ride, all seems to be sweet.
Bruce Bakken
- missionkz
Re: Slipping clutch
04 Jun 2015 22:21 - 04 Jun 2015 22:21Did you think to check the thickness of the friction plates? I was SHOCKED doing a clutch replacement on a Z1 many years ago with so little wear.bb41077 wrote: U guys r all awesome I put everything back together adjusted the cable and changed the oils again and took it for a ride, all seems to be sweet.
I felt guilty letting the guy pay for lunch and beverages for me to do it ....since the plates were still well within spec after 22,000 miles. But it's what he wanted. I kept the plates and later used them on an old LTD with about 40K miles on it that did have slipping clutch pack.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 04 Jun 2015 22:21 by missionkz.
- element303
Re: Slipping clutch
05 Jun 2015 19:24
not sure if that helps right now, but in case you buy new plates and springs like i did and still have a slipping clutch, install spacers between the spring and the bolt. thats what i did last week and i rarely get slipping anymore.
- spdygon
Re: Slipping clutch
05 Jun 2015 20:55
if you install new clutches and still fill it slipping then u probably have a worn out clutch hub , pressure plate or both.
1974 Z1 900 project
1974 Z1 900 project
