Slipping clutch
- bb41077
Bruce Bakken
- missionkz
If the steel plates are blued anywhere or warped... they have to go too!!
Z1 Enterprise has good aftermarket friction plates at a very reasonable prices.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- bb41077
Bruce Bakken
- missionkz
Don't clean them, just get a new set.bb41077 wrote: ...What should I use to clean um up with??, put it back together dry or soaked in oil?
I always wet my friction plates with new/clean engine oil before assembly. I don't know what others do.
So, with the basket spinning and the clutch lever pulled in, the new plates will separate from the steel and get soaked in oil anyhow but I like them wet first.
Bruce
1977 KZ1000A1
- spdygon
- Thank you received: 117
IF METAL PLATE ARE BLUE....TAKE A NYLON OR BRUSH WHEEL AND GIVE ITA GOOD CLEANING...UNLESS WARP.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
- bb41077
Bruce Bakken
- 80B4
- Thank you received: 105
1980B4 1000
1978 Z1R
1978 B3 750
- Thank you received: 2829
What oil have you been using?
- bountyhunter
- Thank you received: 337
- missionkz
I just measured a handful of "new in the OEM Kawasaki parts bag" friction plates and they all averaged 3.78mm to 3.81mmspdygon wrote: FIDER PLATES.........ANYTHING BELOW 3.50MM...REPLACE...NORMAL IS 3.65MM TO 3.80MM
Bruce
1977 KZ1000A1
- spdygon
Make sure your clutch lever is not to tight.
1974 Z1 900 project
- bb41077
