Slipping clutch
  • bb41077
  • bb41077's Avatar Topic Author
Slipping clutch
04 Jun 2015 11:14
#675224
So my clutched started slipping when I'm accelerating, have to let off and slowly get into it. I just took it apart to see if its shattered, but it looks fine, no nothing weird looking, what should I be looking for?? Can I just clean the plates off and put back in. What should I use to clean um up with??, put it back together dry or soaked in oil?
Bruce Bakken
  • missionkz
  • missionkz's Avatar
Re: Slipping clutch
04 Jun 2015 11:25 - 04 Jun 2015 11:42
#675225
Clutch: friction plates are not expensive. Seriously.. at this stage... just replace them.
If the steel plates are blued anywhere or warped... they have to go too!!
Z1 Enterprise has good aftermarket friction plates at a very reasonable prices.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 04 Jun 2015 11:42 by missionkz.
  • bb41077
Re: Slipping clutch
04 Jun 2015 11:38
#675227
Ya I think its time to just replace them they r getting worn down. The plates look brand new so I think I'm solid on them
Bruce Bakken
  • missionkz
Re: Slipping clutch
04 Jun 2015 11:45
#675228
bb41077 wrote: ...What should I use to clean um up with??, put it back together dry or soaked in oil?
Don't clean them, just get a new set.
I always wet my friction plates with new/clean engine oil before assembly. I don't know what others do.
So, with the basket spinning and the clutch lever pulled in, the new plates will separate from the steel and get soaked in oil anyhow but I like them wet first.
Bruce
1977 KZ1000A1
  • spdygon
  • spdygon's Avatar
Re: Slipping clutch
04 Jun 2015 11:47
#675229
FIDER PLATES.........ANYTHING BELOW 3.50MM...REPLACE...NORMAL IS 3.65MM TO 3.80MM
IF METAL PLATE ARE BLUE....TAKE A NYLON OR BRUSH WHEEL AND GIVE ITA GOOD CLEANING...UNLESS WARP.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • bb41077
Re: Slipping clutch
04 Jun 2015 11:51
#675230
What's a good clutch plate to buy then there seems to be so many different kinds and different priced. I just want to get the right one of course and I'm newer to this so I could use some advice. Thanks
Bruce Bakken
  • 80B4
  • 80B4's Avatar
Re: Slipping clutch
04 Jun 2015 12:12
#675232
Replace the springs. Your factory manual should list the minimum length and yours are collapsed.
1980B4 1000
1978 Z1R
1978 B3 750
Re: Slipping clutch
04 Jun 2015 12:26
#675237
The stock clutch disks last a VERY long time,and that's what I would use to replace the old ones. It's possible using the wrong motor oil ruined yours.
What oil have you been using?
  • bountyhunter
  • bountyhunter's Avatar
Re: Slipping clutch
04 Jun 2015 12:47
#675239
Oil is the first thing I thought of too.
  • missionkz
Re: Slipping clutch
04 Jun 2015 13:17
#675242
spdygon wrote: FIDER PLATES.........ANYTHING BELOW 3.50MM...REPLACE...NORMAL IS 3.65MM TO 3.80MM
I just measured a handful of "new in the OEM Kawasaki parts bag" friction plates and they all averaged 3.78mm to 3.81mm
Bruce
1977 KZ1000A1
  • spdygon
  • spdygon's Avatar
Re: Slipping clutch
04 Jun 2015 15:09
#675251
What kind of oil are u using? Has the bike been sitting for long time?
Make sure your clutch lever is not to tight.
1974 Z1 900 project
  • bb41077
Re: Slipping clutch
04 Jun 2015 15:52
#675253
Valvoline motorcycle 4 stroke 10\40
Bruce Bakken
