Cylinder head bolt rubbery coating
Re: Cylinder head bolt rubbery coating
24 Jan 2015 07:24
I'll try that but they are ads from this site.
24 Jan 2015 07:42TexasKZ wrote: No matter which bolt you use, you will need the copper washers. The soft copper forms the seal that prevents oil seepage under the bolt head. Are the heads of the new bolts about the same diameter as the flange on the old ones?
You do need those washers on the head bolts, but not on the valve cover bolts. The valve cover bolts did not come with washers and mine have never had any oil weepage. Ed
24 Jan 2015 08:07
Ed's right, the valve cover is made so the gasket seals the bolt shaft.
24 Jan 2015 08:09toolmaker wrote:swest wrote:
I just got redirected to another ad. This time View New Messages. I don't want to make ask my default or make any changes to my computer. I've declined but it still happens,
I have had that happen in the past - it is probably a bug in your computer. Have your anti-virus program check it out.
Just ran my anti virus and had to restart my computer. Ask was the threat. 2 of them.
- KZB2 650
24 Jan 2015 09:24
I've always just used a 10mm socket or wrench with a dab of anti sieze.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
24 Jan 2015 09:36
I've never done that. Might have saved some threads that way.
- Tyrell Corp
24 Jan 2015 10:52
I have a small pot of coppaslip grease and a toothbrush, every stainlss allen bolt gets a smear of anti seize. Stainless in ally is worse for corrosion than high tensile in ally.
Trivia on rounded bolts, if the corners are flatted I dump my Britool spanner and instead use a snap-on flank drive that grips only the flats.
- pete greek1
24 Jan 2015 11:23
I use a 1/4 inch Torque Wrench ....& also make sure to follow the right tightening sequence, that's in your manual
Pete
Pete
- gcphoto
24 Jan 2015 13:06
The allen head bolts fit just fine, look good and lock tight without washers (no washers were there with flange bolts). But if they're not good to use in that spot i'll get new flange bolts.
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
___________
24 Jan 2015 13:27 - 24 Jan 2015 13:31
There is no reason to use lock tight on cylinder head cover bolts. Doing that is only asking for trouble later. Use it ONLY where the torque specs in the Kawasaki Service Manual call for it. There are 24 bolts holding that cover down; believe me, you don't need lock tight to keep it or the bolts from falling off.
If you are using stainless bolts you may want to use some anti-seize to prevent galling, but that is not the same stuff as lock tight. Ed
Last edit: 24 Jan 2015 13:31 by 650ed.
- gcphoto
24 Jan 2015 13:44
I didn't mean I used loctite. I meant they "locked tight" without washers. :lol:
I've got the manual and will follow all specs. My only last question was whether you thought those allen heads were good or if you thought I ought to stick to the flange bolts. The allen heads seem to work well but the diameter is a slight bit smaller than the flange bolts. If I had a washer to the allen they become the same.
'78 KZ650 SR
___________
___________
24 Jan 2015 14:01
Ed is right. With the small cam cover bolts no washer is needed. You should befinewith the a stainless as long as they each get a dab of anti seize on the threads.
The following user(s) said Thank You: gcphoto
