Cylinder head bolt rubbery coating
- gcphoto
23 Jan 2015 14:21
Hey guys.. what the heck is this? I got the new stainless steel bolt package from Z1 to replace all the old gnarly looking screws with nice new allen heads. I replaced a couple of the cylinder head bolts and one came out with a clear rubbery looking sleeve. I wanted to check what you guys thought this was and if I needed to add some kind of coating to these bolts. You can see in the picture that it starts at the threads and runs up the shaft about an inch in total. I've seen recommendations for using loctite blue and/or permatext high temp thread sealant. Is this correct?
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
___________
- GUTS
Re: Cylinder head bolt rubbery coating
23 Jan 2015 15:10
Looks like they put high temp silicone under the cap nuts. I just replaced the ones on my Z1 and they have copper washers under them not silicone.
23 Jan 2015 15:32
It looks like a previous owner never should have been allowed to own a wrench! It should not be there. Ed
The following user(s) said Thank You: gcphoto
- gcphoto
23 Jan 2015 15:41
Lol! Thanks Ed. So the correct treatment is blue loctite or is it the high temp thread sealant from Permatex which specifically states it's for head bolts?
You can see it
here if you're not sure what I'm talking about.
'78 KZ650 SR
___________
___________
23 Jan 2015 15:48 - 23 Jan 2015 15:50
No. You should not use anything at all on the head bolts. Take a look at the torque table in your Kawasaki Service Manual. You will notice t does not call for any sealant or thread lock. Do you have the correct washers? Ed
Last edit: 23 Jan 2015 15:50 by 650ed.
- gcphoto
23 Jan 2015 16:11
SS flat washers?
'78 KZ650 SR
___________
___________
23 Jan 2015 17:00
I think they are usually copper.
23 Jan 2015 17:57
Are these the 14mm hex cap nuts we're talking about? If so, no Lock Tight, copper washers. Don't use sealent on any threads anywhere. Good way to strip or bust a case by hydro-static pressure.
I keep being redirected to ads. What's happening?
- gcphoto
23 Jan 2015 17:58
Oh ok, just regular copper crush washers
'78 KZ650 SR
___________
___________
23 Jan 2015 17:58gcphoto wrote: Hey guys.. what the heck is this? I got the new stainless steel bolt package from Z1 to replace all the old gnarly looking screws with nice new allen heads. I replaced a couple of the cylinder head bolts and one came out with a clear rubbery looking sleeve. I wanted to check what you guys thought this was and if I needed to add some kind of coating to these bolts. You can see in the picture that it starts at the threads and runs up the shaft about an inch in total. I've seen recommendations for using loctite blue and/or permatext high temp thread sealant. Is this correct?
That's scary. :ohmy:
- gcphoto
23 Jan 2015 18:03
'78 KZ650 SR
___________
___________
23 Jan 2015 18:31 - 23 Jan 2015 18:32
OK. If you are talking about the fasteners shown as #1 and #11 in the diagram those are not head bolts. Those are cylinder head cover (valve cover) bolts. They do not use washers since they are flanged, and they do not use any sealant, thread lock, or anything else. Ed
Last edit: 23 Jan 2015 18:32 by 650ed.
