Z1 engine with no serial numbers?
  • K.D. HART
  • K.D. HART's Avatar Topic Author
28 Dec 2014 14:17 - 28 Dec 2014 14:25
#657205
Didn't know really where to put this question, so posted it here in the engine section.
I picked up this 1975 Z1 last week that doesn't numbers stamped into the engine cases.
I know they haven't been filed off either. The casting ridge around the stamping area is still in tact.
Would this been a damaged motor back in the day and Kawasaki replaced the cases with one's that weren't stamped?
[IMG
Last edit: 28 Dec 2014 14:25 by K.D. HART.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Z1 engine with no serial numbers?
28 Dec 2014 15:34
#657215
I have also a set of unmarked 550 cases.
Given the cost of those crankcases - sold as a matched pair, it guess it would only really be a warranty repair job back in the day. There were some NOS cases on ebay while ago also unmarked.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
28 Dec 2014 15:43
#657217
Those are likely warranty cases. Do you have a valid title for the motorcycle? There might be issues if you are attempting to register the motorcycle in any state other than the one where the current title was issued. I had a set of blank warrantied cases in a 1977 KZ1000A...had a few hoops to leap through in California when I moved the bike to Texas.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • K.D. HART
28 Dec 2014 15:48
#657219
Mcdroid wrote: Those are likely warranty cases. Do you have a valid title for the motorcycle? There might be issues if you are attempting to register the motorcycle in any state other than the one where the current title was issued. I had a set of blank warrantied cases in a 1977 KZ1000A...had a few hoops to leap through in California when I moved the bike to Texas.
Yes, I have the title.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
28 Dec 2014 16:47 - 28 Dec 2014 17:09
#657223
Not in your case, but in some......could be a stolen engine, they would remove the number off the cases. You can tell if it had been removed, the very outside of the stamped area had a raised lip all the way around. If the raised lip is gone, then it was messed with.
In Ohio, the DMV only cares about the frame or neck number, they could care less about the engine number.
The Ohio insurance company does care about the engine number and requires it.
Last edit: 28 Dec 2014 17:09 by 4TheKZ1000.
  • K.D. HART
28 Dec 2014 16:54
#657225
4TheKZ1000 wrote: Could be stolen engine, they would remove the number off the cases. You can tell if it had been removed, the very outside of the stamped area had a raised lip all the way around. If the raised lip is gone, then it was messed with.
I doubt it was stolen, I bought it from a cop.
It hasn't been filed down either. Read my first post.
  • z1kzonly
  • z1kzonly's Avatar
28 Dec 2014 17:05
#657229
WHAT EVER? YOU DON'T LIKE IT?
I,LL BUY THE ENGINE CHEAP!
  • DFIGPZ
  • DFIGPZ's Avatar
28 Dec 2014 17:30
#657231
Yep Replacement cases came unstamped as did frames.
1984 750 Turbo
  • K.D. HART
29 Dec 2014 07:15
#657267
z1kzonly wrote: WHAT EVER? YOU DON'T LIKE IT?
Did you eat lead paint chips as a kid?
  • z1kzonly
  • z1kzonly's Avatar
29 Dec 2014 07:38
#657271
Probaly, I lived in ghetto Buffalo, Lots of lacquer fumes too, I started priming, sanding and painting when I was 15.
Washed parts in trichloroethylene with no gloves, always had a 5 gal. pail of carb cleaner (Gunk Solder Seal) the real bad stuff in the garage. Just to name a few. Could explain it. Made it to 57 now, no growths or goiters growing on me yet, anyway.
But, I hope you got the motorcycle for a decent price, it looks nice!
And all the titles go by the frame Z1F--- Don't worry about engine, stamp the #'s yourself.
I have dozens of times including frames over the last 40 years.
They use a simple 1/4" basic, straight up stamp.
Now Harley was a whole different story, they purposely changed angles, had different star shapes, off center. Every few years back in the early days of Pan & Shovel head. They changed them up. Which the DOT new about.
Sorry if I offended anyone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Dec 2014 08:13
#657274
Yeah Kawasaki had extra cases and didn't stamp the racing ones ether. Do a title search to find the dealer and if still around get a statement form them.
  • GregZ
  • GregZ's Avatar
29 Dec 2014 09:38 - 29 Dec 2014 09:41
#657281
Quote z1kzonly
"And all the titles go by the frame Z1F--- Don't worry about engine, stamp the #'s yourself."
I'm pretty sure back in the day Wisconsin titles there motorcycles from the engine. I dragged several home from the cheese state and that's how there were titled..Probably because Harly Davidson never had numbers on the frame on the early bikes.
Plus I recently picked up a 75 z1 from Arkansas and it was titled against the motor
As far blank z1 engines I have seen several of those myself. They are factory replacement engines. I can go buy a complete never fired new in crate over the counter z1/kz900 engine small exhaust studs. It has blank stamp pad with the ridge like late 74 75 z1
$10k for the crate engine and a completely restored 75 z1
Last edit: 29 Dec 2014 09:41 by GregZ.
