Pistons 2&3 stuck
- pete greek1
Re: Re:Pistons 2&3 stuck
30 Nov 2014 18:08
Was it a folded ring ??
- kaw-a-holic
30 Nov 2014 20:28 - 30 Nov 2014 20:29Yep, just the very bottom oil ring on both 2 & 3. I will have to make a ring compressor so I can prevent it from happening again.pete greek1 wrote: Was it a folded ring ??
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
Last edit: 30 Nov 2014 20:29 by kaw-a-holic.
01 Dec 2014 06:34
Take a feeler gauge and measure the space between the cylinder walls and pistons. First at the top, then in the middle and the bottom. Measure at four points around the pistons. 12:00, 3:00, 6:00, 9:00. Measure your pistons as well,top then bottom. Loose pistons can be noisy and you can bust a skirt. That happened to me 30 years ago. I left a smoke trail a mile long all the way home. Do it right the first time and you won't be disappointed. Doesn't sound like you need to split the cases.
Good luck.
Good luck.
The following user(s) said Thank You: kaw-a-holic
- turboking
Re: Pistons 2&3 stuck
01 Dec 2014 07:31
:ohmy: :huh: sounds like a laid over oil ring or loose wrist pin clip............. :S :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- kaw-a-holic
Re: Re:Re: Pistons 2&3 stuck
01 Dec 2014 11:29Folded oil ring. No major damage found thus far.turboking wrote: :ohmy: :huh: sounds like a laid over oil ring or loose wrist pin clip............. :S :dry:
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
01 Dec 2014 13:46
i'm pretty sure you don"t have to worry about any crank damage sir.
just get some new rings and slip it all back together you'll be fine.
