Pistons 2&3 stuck
  • kaw-a-holic
  • kaw-a-holic's Avatar Topic Author
Pistons 2&3 stuck
28 Nov 2014 10:26
#654844
Guys I need your help. I am reassembling my stock kz1000 engine. I dropped something down the timing chain slot when to pull my jugs to retrieve it and the #2&3 pistons won't let go. I sprayed WD-40 around the top of the cylinder walls and it is not going anywhere. I have yanked, cussed and tapped the top of the piston with a wooden handle and a hammer and they just won't budge.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • pete greek1
  • pete greek1's Avatar
Re: Pistons 2&3 stuck
28 Nov 2014 10:32
#654845
Maybe if you drop the oil pan, you can see what the problem is
Pete
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
28 Nov 2014 10:34
#654846
Ummmmmm... WD40 is not really a lube... more of a water repellent. Might want to get something like Kroll, or make your own with Acetone and ATF (50/50).
Oh, the other thought that (sarcastically) comes to mind... get a bigger hammer! :lol:
Good luck and keep us posted with what you find the problem to be and the fix...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • kaw-a-holic
Re: Re:Pistons 2&3 stuck
28 Nov 2014 10:50
#654850
The oil pan is not on it. The bigger issue right now are the stuck pistons. If I can't get the jugs off the starter certainly won't turn the crank. :-( I will get some Kroll, spray it and leave it alone for a while. Thanks guys. Any other suggestions in the mean time are certainly welcome.
Jon
1977 KZ1000a1
Mesa, AZ
  • Nessism
  • Nessism's Avatar
  • Away
28 Nov 2014 10:58
#654852
I don't understand what's going on. You mention "reassembling the engine", which implies it's been apart already. Then some reference to dropping something down the cam chain slot, but I don't understand what this has to do with getting the cylinder to pull off.
Has the engine sat for a long time? Could the rings be rusted to the bores? If so, than that spray oil may help. What am I missing?
  • floivanus
  • floivanus's Avatar
28 Nov 2014 12:46
#654863
Dropped something down the chain slot? Is it bound up between the chain and crank and that's what is keeping the pistons stuck? If those two are stuck arent the other two? You only have one block so 2&3 arent stuck, all four are? If your crank doesnt turn and you are reassembling them the crank is jammed up; if you cant pull the object out (magnet, long pick etc) flip the engine out and jiggle it loose; otherwise split the case and pull the crank center cap?
Past; 78 kz1000, 83 kz550
Andrew
  • kaw-a-holic
Re: Re:Re: Pistons 2&3 stuck
28 Nov 2014 14:27
#654868
Crank turns fine. 1&4 are out. When I pull up on the jugs the crank spins until 2&3 are at the top and stops. I took the jugs and head off to have the head done, replaced rings after honing cylinders. I oiled the cylinders compressed the rings and slid the jugs over the pistons. Everything went smoth until I tried to remove the jugs again and realized 2&3 were stuck in place.
Jon
1977 KZ1000a1
Mesa, AZ
  • kaw-a-holic
28 Nov 2014 15:03
#654871
I couldn't find Kroll oil at the auto parts store. I got some liquid wrench instead. It's just sitting on top of the piston. It has been for 2 hours now. I'm just hoping over night or a few days will get it done. Maybe I need to go 1075 after all.;-)
Jon
1977 KZ1000a1
Mesa, AZ
  • PLUMMEN
  • PLUMMEN's Avatar
28 Nov 2014 15:10
#654873
Try some gas/trans fluid in the cylinders to loosen them up. ;)
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
28 Nov 2014 15:20
#654874
Question... 2 & 3 didn't get a bit skewed in the cyls' did they? ...and bind up for this reason? (just askin')
I mean... from what your OP reads, it sounds like you're in the middle of a rebuild and the motor has not yet been run, right? So I don't understand what's binding 2 & 3... When everything was on... can I presume you've had the head on(?)... did you spin the crank and everything moved ok? (just trying to understand where you are with all of this)
C.
  • PLUMMEN
  • PLUMMEN's Avatar
28 Nov 2014 15:46
#654876
!Seymore wrote: Question... 2 & 3 didn't get a bit skewed in the cyls' did they? ...and bind up for this reason? (just askin')
Maybe the rings folded over? :S :S
The following user(s) said Thank You: peter1958
  • gpz1170
  • gpz1170's Avatar
28 Nov 2014 16:35
#654879
if you are not putting tension on the cam chain when turning the crank, it will bind ( wad up ), locking up the motor.
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
