Pistons 2&3 stuck
- kaw-a-holic
Re: Re:Re: Pistons 2&3 stuck
29 Nov 2014 06:33It has not run, the head has not been on. I think your right, the piston/pistons must be skewed.!Seymore wrote: Question... 2 & 3 didn't get a bit skewed in the cyls' did they? ...and bind up for this reason? (just askin')
I mean... from what your OP reads, it sounds like you're in the middle of a rebuild and the motor has not yet been run, right? So I don't understand what's binding 2 & 3... When everything was on... can I presume you've had the head on(?)... did you spin the crank and everything moved ok? (just trying to understand where you are with all of this)
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
29 Nov 2014 06:34I had the cam chain pulled straight up and zip tied out of the way.gpz1170 wrote: if you are not putting tension on the cam chain when turning the crank, it will bind ( wad up ), locking up the motor.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
29 Nov 2014 06:35Can this happen?PLUMMEN wrote:Maybe the rings folded over? :S :S!Seymore wrote: Question... 2 & 3 didn't get a bit skewed in the cyls' did they? ...and bind up for this reason? (just askin')
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
29 Nov 2014 06:46
You might move the barrels all the way up, then put some wood blocks between the sleeves and move the crank back and forth with a wrench. Sounds to me a oil ring may be jammed between the piston and cylinder. Do it gently and hopefully the pistons will drop out the bottom. Good luck.
- kaw-a-holic
Re: Re:Re: Re:Re: Pistons 2&3 stuck
29 Nov 2014 07:32Thanks Steve. The good news is that the liquid wrench was NOT sitting on top of the pistons this morning. I sprayed some more and am going to leave it alone while I take a family day. Hopefully this evening will have some positive resultsswest wrote: You might move the barrels all the way up, then put some wood blocks between the sleeves and move the crank back and forth with a wrench. Sounds to me a oil ring may be jammed between the piston and cylinder. Do it gently and hopefully the pistons will drop out the bottom. Good luck.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- Motor Head
29 Nov 2014 08:19Like Plummen said, I think that you may have gotten an oil ring bent when putting the cylinders on. If just one ring is tweaked, sticking out of its groove, being between the piston and cylinder, it will be stuck.kaw-a-holic wrote:Can this happen?PLUMMEN wrote:Maybe the rings folded over? :S :S!Seymore wrote: Question... 2 & 3 didn't get a bit skewed in the cyls' did they? ...and bind up for this reason? (just askin')
Place a couple of pieces of wood under each side of the cylinder block, between the case and the block. With the rods mid stoke, Use another piece of wood and as a punch and a hammer to tap down on the pistons. Hopefully they will come loose and not be damaged. You may need another ring set for one piston. Someone on here may have a couple of oil rings or a set for one piston.
The following user(s) said Thank You: kaw-a-holic
- kaw-a-holic
Re: Re:Pistons 2&3 stuck
29 Nov 2014 10:55
Thanks Motorhead, that's the plan, I just wanted the liquid wrench to get a chance to get in there and help a bit. Hopefully I will have some good news this evening.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- !Seymore
- Ride on...
29 Nov 2014 11:32 - 29 Nov 2014 11:34swest wrote: You might move the barrels all the way up, then put some wood blocks between the sleeves and move the crank back and forth with a wrench. Sounds to me a oil ring may be jammed between the piston and cylinder. Do it gently and hopefully the pistons will drop out the bottom. Good luck.
I like the "move the crank" option, as opposed to the "tap on the piston". Might also try to move it more the position, opposite to what may have bent the ring, if you can guess/remember where 2 & 3 were when this problem started. May help to get it loose.
Also, might measure from the top of the cyl walls to the front and back of pistons 2 & 3, the cyls even with blocks beneath. Compare and see if either are askew... (troubleshooting?)
But enjoy your "family day" first... they do come first, in my household.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 29 Nov 2014 11:34 by !Seymore.
29 Nov 2014 12:55 - 29 Nov 2014 19:45
I don't see what good penetrating oil is going to do. That stuff is designed to loosen corrosion and the like from fasteners that have been in place for a long time. The stuck pistons don't apply if I'm understanding correctly. As the others have said there must be a folded ring or similar. Hope you don't tear up the cylinder wall or piston getting the cylinder back off.
Last edit: 29 Nov 2014 19:45 by Nessism.
- kaw-a-holic
29 Nov 2014 17:03I was hoping it might lube it just a little to help? It probably won't.Nessism wrote: I don't see what good penetrating oil is going to do. That stuff is designed to loosen corrosion and the like, from fasteners that have been in place for a long time. The stuck pistons don't apply if I'm understanding correctly. As the others have said there must be a folded ring or similar. Hope you don't tear up the cylinder wall or piston getting the cylinder back off.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
29 Nov 2014 17:14kaw-a-holic wrote:Thanks Steve. The good news is that the liquid wrench was NOT sitting on top of the pistons this morning. I sprayed some more and am going to leave it alone while I take a family day. Hopefully this evening will have some positive resultsswest wrote: You might move the barrels all the way up, then put some wood blocks between the sleeves and move the crank back and forth with a wrench. Sounds to me a oil ring may be jammed between the piston and cylinder. Do it gently and hopefully the pistons will drop out the bottom. Good luck.
Please don't pound on the piston. The best you can do is shock one bearing at a time in hopes of moving both pistons. That's a last resort. Aluminum doesn't take shock very well and may crack even if you don't see it. I said at the top of 2/3 piston stroke. That way they can only come down. Using pressure on the crank and a light tapping one to the other should coax the pistons down. Remember, you have rod bearings, wrist pins, pistons and skirts to think about. The last thing you want is any of them to come apart once it's back together.
- kaw-a-holic
30 Nov 2014 17:40
Well I got them out. No major damage to the cylinder walls. Will have to rehone but the sight scratches I do have are in the skirt area so all is good. What I don't know is if any damage has been done to wrist pins or crank bearings. I really don't want to split the cases.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
