running out of ideas! kz550a
- loudhvx
Re: running out of ideas! kz550a
12 Nov 2014 18:13
Tyrell beat me to it... a wet compression test will let you know if it's your rings. Put a small squirt of oil in the cylinders before doing the test. That will seal up the rings. If compression goes up a lot, then it's the rings leaking air. If not, then valves.
Repeating: do the test engine hot, choke off, throttle wide open, all four plugs out (but all four plugs grounded or the small coil wires disconnected, if not, you can damage the ignition). Make sure the gauge is made correctly.
But how long does it take for new rings to seat? You might not have enough miles on it.
I guess you need to get it somewhat running to get the miles on it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Jeff86
14 Nov 2014 10:29Tyrell Corp wrote: 135- 140 psi hot compression seems ok to me - most compression testers aren't that accurate. Try a wet test to narrow down the problem further. The zx550 models have 280 degree cams, the z550 models are IIRC 248 degrees: the wilder the cam the lower the cranking pressure . I don't think this 'low' compression is your problem anyway, more likely being chronically over rich.
Firstly I'd equalise the main jets at 105, . The big suzukis have differing inner cylinder fuelling to compensate for the heat differences but i'm not sure kawasaki did it onany of the kz models.. Just one step to 107.5 is enough to make it unrideable at WOT. Tune top to bottom, ie get your WOT main jet set, then needle etc
Your coils should be at B+ voltage, low coil voltage causes misfires and the ' relay mod' is just folklore and witchcraft. Also I'd use new HT leads and caps all round.
Even if the motor is a bit tired it should still pull hard to the redline. A bit more explaination of your symptoms might help too.
Thank you, I will try the HT caps and wires and new plugs before I start messing with jetting again,
I will also try and do a poor mans leak down test and a wet compression test. just to confirm. The valves worry me because I did it all myself for the first time.
I will have to check the voltage of the battery and at the coils while running at idle and at higher Rpm.
the stock jets are 92, I think maybe the jump from 92 to 105 is maybe to large.
does anyone have information of reassembly of the TK22's maybe I am doing something wrong when i set them up and bench sync.
what would be the main culprit of having no vacuum to pressurize the carb sync tool? this is one of my main concerns now. i cant understand what would cause this.
Thanks for the help so far guys.
very much appreciated
- Jeff86
14 Nov 2014 10:37loudhvx wrote:Jeff86 wrote: Interesting my Manual say 130 is min before service and 150 is stock. Ill check another manual as well. if my cam timming is not set correctly would this alter my compression. I cant see it being the rings, they are new, and the jugs were in great shape. plus i dont see or smell burning oil. and the oil level has not dropped. is there somewhere on here that explains a leak down test? or how to do it?
I have several manuals in my signature. For reference, you should grab all of them. The 155psi limit comes from the FSM which starts out with the Kz500. I see no mention in the supplement for the later models, including the gpz550 (which has higher compression), so I assume they meant that limit for the entire 400/500/550 family. The Clymer manual states 125 psi as the limit, likewise, no mention in the supplement for the later years. In my epxerience measuring mostly Gpz Kz550's, the compression measured on many motors, over many years, using many different gauges, was always around 180 psi, for stock motors. I only have one motor that may have been shaved as it gets near 200 psi. To me, even 150 sounds very low, and so 120 sounds very low. The larger motors (650/700/750 family and 900/1000 family) do seem to have lower compression pressures based on seeing what's been posted on Kzrider. They tend to run even down around 100 psi. I have some worn engines, and they are still up around 180 psi.
I believe incorrect cam timing would affect compression test numbers, but I've never played with that. You may have already seen the cam-timing notes in my signature, but if not, you can use it to compare what yours is set at.
You basically connect an air compressor hose to a spark plug fitting and inject air into the cylinder through the spark plug hole when at TDC of the power stroke. You can buy the fitting, or you can bust up a spark plug and weld (braze etc) a pipe to it. That's what I did.
You will hear hissing if it's leaking. It may hiss through the intake, or exhaust, or through the crankcase. Where you hear it will tell you where it's leaking.
Have you used other compression gauges before? Some are not made right. There needs to be a check valve at the very tip that goes into the cylinder. Sometimes they put the check valve far away from the tip. This results in very low numbers. The gauge must hold pressure across several compression strokes because the added volume of the test equipment requires more air to be pumped. Once the test equipment is up to a constant pressure, that's the most pressure the motor can build for the test. Putting the check valve further in lets air dump out of the test equipment, so each pulse never reaches full pressure. It's almost as if they didn't even understand what they were making, or what it was supposed to do. China.
Jeff86 wrote: ... but how can it be this rich with the 30 pilots and needle on the third? the mains are not doing anything at start or idle, correct?
Needle on third clip is a lot richer than stock. But with pods, I would not expect it to be too rich. Correct, the main has negligible affect at idle, but on start, it depends on how you start. On mine, when I know I need more fuel at startup, I give it a lot of throttle, so the mains do affect it. There may even be some affect if you start with no throttle, but I doubt it. Starting is too chaotic to really predict, but at idle, the needle does have some affect.
Where are your screws set at?
they are at 1.5 turns out.
Jeff86 wrote: ...when I got the bike the previous owner had 96's. but the bike didnt run from the beginning. so i never tried them and had always assumed i needed bigger based on web searches.
The 96's are probably the stock Gpz 1981 Kz550D1 jets. I assume you would probably need to go bigger than 96, but I would try them as is first. With a quiet exhaust, they might work.
Just to reiterate, when checking the mains, you need to check this first:This being set beyond full open will sometimes result in the sensation that the bike is speeding up as you just start to close the throttle from WOT.It is possible for the throttle to open past full-open. Beyond that, you only add more fuel, but no more air. The Tk22 site shows how to tell where the slide is at. Actually, with pods, you can just take one off and see if the slide goes higher than the ceiling of the carb throat.
Great i will check this out tonight
Jeff86 wrote: They had told me that with pods at idle and roll of that you actually get less air then the stock air box, because the air is not being funneled or controlled so the suction or vacuum is lower.
In my experience, jetting several 550's with TK22's and pods, this does not hold up. With pods, it always ends up leaner than with the airbox, under all conditions that I've checked.
I wonder, though. Does having significantly lower compression mean you need less jetting since the engine is not breathing as well as it should? I recall my friend having a really high-mile, very low compression, Kz650, and it kept fouling plugs. It was originally was jetted with pods and supposedly ran good. But years and many miles later, it was fouling plugs pretty badly. I reduced the jetting a lot to dry up the plugs, but it still wasn't right. My buddy sold it before I could really spend any time on the jetting. We replaced the entire ignition system and did a valve clearance check. The compression being very low was all I could find wrong. I think it was somewhere around 120 psi as well.
This makes sense to me, I can see how lower compression would alter the jetting a lot.
Jeff86 wrote:
which brings me to another point. when trying to synch the carbs, we could barely get the gauges to move. 2-4 moved up slightly, i forget the number but it was low. #1 would not move no matter what we did.
That's not good. With a fast idle, on the gpz, I get about 20 cm of mercury with pods.
It's a lot of reading, but here are my notes on manometers in general.
home.comcast.net/~loudgpz/GPZweb/Manomet.../ManometerNotes.html
This you tube link shows my manometer in use on the gpz so you can see how it looks with throttle blipping etc. (It was a really cold day, so I had the idle way up to get off the choke.
as much as I dont want to read it all I will. this motorcycle stuff is heavy reading all the time! lol
Jeff86 wrote: I will order some stock jets and go from there. I have the drill set to go bigger if need be. sadly i cant make this jet kit i bought smaller! dang
do you know if the Z1 Keihin main jets are good to use on this bike?
www.z1enterprises.com/ItemDetails.aspx?i...00&item=SIKHM-110100
I would rather just order a bunch of main and keep trying them until i figure it out.
- loudhvx
15 Nov 2014 13:22 - 15 Nov 2014 13:24Jeff86 wrote: do you know if the Z1 Keihin main jets are good to use on this bike?
I'm not sure. I don't know the models of carbs the compatible jets came out of.
But here are some measurements.
home.comcast.net/~loudgpz/GPZweb/TK22mai...22jetsAndDrills.html
If you notice, the orifice on the different types of jets are at different heights. This means they will be at different depths into the gasoline in the bowl. This alters flow rate slightly, and dynamic response during throttle transitions.
The important thing, of course, is to get the threads the same (M5 x .8 and 5mm long). If you are using all of the same jet type, you will be comparing apples to apples.
If you contact Z1enterprises, they can probably confirm the thread diameter and pitch, along with the thread length. I refer to the corect ones as "small head Keihin" because that is what Jeff, at Z1enterprises, referred to them as at one time.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 15 Nov 2014 13:24 by loudhvx.
- DOHC
- Those Doe-Hawks really go!
15 Nov 2014 14:24 - 15 Nov 2014 14:24Jeff86 wrote: ...how can it be this rich with the 30 pilots and needle on the third? the mains are not doing anything at start or idle, correct?
A somewhat unlikely answer to your question is that the air inlet ports for the air-screw/idle-mixture circuit could be blocked.
My first bike, a '77 KZ650, sat outside for a while before I got it. Every single air-port in each carb throat was plugged with bee mud, with a tiny bee larva in each hole. In that state it did run but would foul a set of plugs in about 2 miles.
As I said, it's not very likely, but it is possible.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 15 Nov 2014 14:24 by DOHC.
- Tyrell Corp
15 Nov 2014 18:27
Yes - the lack of inlet vacuum at idle is worrying, not getting any vaccum in one cylinder points to air leaks or valve clearance issues. A vac guage can be as good as a compression tester for diagnostics.
I think the kz are 9:1 compression, the gpz 10:1 but the earlier lower duration kz cams should actually increase cranking pressures I would have thought. Not really sure what the pressure should be.
If the bores or new rings rings were really that bad I guess it would be using oil and smoking at rattling enough to be noticed. Also it starts easily - worn bores even worse when cold. .
Resolve this inlet vaccum issue and get results of a compression wet test first. Then looking at the 1 volt drop to the coils plus unusual main jet imbalance is probably where the problems are.
I know one gpz550 I had was on 105 mains with pods and a 4-1,
16 Nov 2014 06:11I will order some stock jets and go from there. I have the drill set to go bigger if need be. sadly i cant make this jet kit i bought smaller! dang[/quoteJeff86 wrote: You said "Dyna S coils". The Dyna S is an ignition kit, but does not include coils. Did you mean Dyna coils? Or did you mean a Dyna S ignition with Dyna coils? Since I see you mentioned points, I assume you only meant the coils. 3 ohm coils are a little low for points. Their life will be shortened by some amount, but should still work for the time being.
Sorry yes I meant to say dyna coils. These are the ones recommended by Z1
What do you mean the timing on the #4 exhaust valve is almost out of spec. You can't independently time each valve. Did you mean lash gap? As long as it's within spec, don't worry.
Yes the valve clearance is what i meant
Since you already have new coils, then I would also recommend an electronic ignition from a later 550/650/750. Or you can use a Dyna S ignition, but since your bike is a single phase charging system, the Dyna S might tax it a bit. The factory system would work well. But I don't think this, alone, is your problem.
I will try and track one down, thanks
The battery should get over 14v and stay there once the RPM's are above 2000 or so. If not, you may want to look into the charging system.
I have not checked it while running. I will do this and report back
The compressions sounds too low. Kawasaki says 155psi is the bottom of the usable range. I wouldn't expect it to run too good that low. But that may improve some with some break-in. I assume you know to do the test hot with no choke and the throttle wide open. A leak down test would be good to see where it's leaking. I think this may be your biggest problem at the moment, if those numbers are in fact accurate.
Your AFR numbers show it's too rich (as you said). And if a KZ550 starts cold with no choke on a cold day, it's definitely too rich. Even in summer, on a bike that is slightly rich, I still have to use some amount of choke on a cold start.
agreed. but how can it be this rich with the 30 pilots and needle on the third? the mains are not doing anything at start or idle, correct?
On a Gpz, with pods, and more open 4-into-1, the largest main I use is a 103. That means a standard (Kz550A or Kz550C) would probably max out at 100 or 102. Maybe with a totally open pipe it would be in the 105 range. Sometimes people use a larger main to mask the effects of using a stock pilot or stock (fixed) needle, So maybe that is why they recommend such a large main, but in your case, it's just too big.
Interesting, when I got the bike the previous owner had 96's. but the bike didnt run from the beginning. so i never tried them and had always assumed i needed bigger based on web searches.
WOT, however, may not give a true indication of the jetting. It is possible for the throttle to open past full-open. Beyond that, you only add more fuel, but no more air. The Tk22 site shows how to tell where the slide is at. Actually, with pods, you can just take one off and see if the slide goes higher than the ceiling of the carb throat. The afr should rarely go richer than 9 or 10 under normal, or even spirited riding, and then only when you've opened the throttle a little too fast. If you go richer to where it's misfiring, the wideband will usually show really erratic numbers. When there is a misfire, and no burn, you have a lot of raw oxygen in the exhaust, so it will often register super lean, even though it's super rich. Then when it fires, it will register super rich.
This brings us to the jet kit. I don't have any experience with that kit. What type of jets does it come with? On the tk site, I have photos posted of the various jets I've come across, for comparison. The pilot #30 is puzzling. I wonder how they got that. There has never been a Kz500/550/400-4 that came with any pilot other than a #32. All of the rebuild kits only come with #32. No other pilot will substitute, so it would be interesting to know where that #30 came from.
They had told me that with pods at idle and roll of that you actually get less air then the stock air box, because the air is not being funneled or controlled so the suction or vacuum is lower. which brings me to another point. when trying to synch the carbs, we could barely get the gauges to move. 2-4 moved up slightly, i forget the number but it was low. #1 would not move no matter what we did.
I assume it came with adjustable versions of the stock needles, as they are the only ones I know of that have 5 grooves (the Dynojet needles have 6). 3rd from the top, as you have it, is a good starting point for the needles.
correct
I have not seen much reason to run richer jets on 2 and 3 (compared to 1 and 4) on the KZ550's. They seem to do well with all four the same. If the two inner cylinders run hotter, they will already be running richer when hot.
Agreed but i was desperate to try anything and thats why I ordered a kit from them. www.6sigmajetkit.com/
I guess the first step is to figure out the compression issue.
Next would be a voltage check on the coils while revving. It should be closer to 14v. (But I don't think this is your problem.)
Next, I would go to 100 mains, and set the air screws using the lean drop method. The idle, when warm, should end up around 11.5 to 12.5 on the AFR depending on outside temp. If the air screws are turned out less than 1/2 turn, you will probably want to up the pilot jet to #32 (stock). Usually, with pods, as long as there are no vac leaks, I find the pilots have to drilled out to at least 34, sometimes 37.
You have a set of jet drills? You can solder the jets, then drill to the right size if you have them.
- loudhvx
16 Nov 2014 08:56 - 17 Nov 2014 15:01
I don't see an easy way to solder and re-drill. The length of the jet orifice is as crucial as the diameter. First you have to clean the jet, probably by drilling larger. When you solder, the entire jet will fill with solder, so you will have to re-drill the orifice and the larger diameters before and after the orifice, but if you go too deep, you will alter the length of the orifice, and have to start over.
Not that it can't be done, but it's a lot more steps and a lot more critical drilling. Whereas just increasing the size slightly is very easy and simple. It's really just a chaser. Very little material actually gets removed.
Edit: the stock Kz550D1 uses 94 mains, not 96, as I said earlier.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 17 Nov 2014 15:01 by loudhvx.
- Jeff86
14 Dec 2014 18:50
Its been about a month since I asked for your help, I finally had a chance to try out some of the suggestions.
i replace all the main jets with 100's
Replaced all the spark plug wires and caps with 7mm non suppression dyna set.
put in all new spark plugs and then went for a test ride.
I tried it on the third needle clip and then the second. The second was much better! but still sounded like it was misfiring and still way to rich. to the point that I fouled the O2 sensor and it shut off.
I tried the make shift leak-down test but really didnt have much luck finding anything. my make shift tester was not really optimal. I am going to order a real tester and go from there,
This all got me thinking though.
Lets just assume that the compression is fine for a second. and that i am getting good power to the spark plugs.
what else could it be? well the bike had been "customized" before i bought it. the jetting had been changed already as it had pods on it. I started to think what else could a "home mechanic" do to the carbs to try and get more fuel?
what if the jet holder (emulsion tube) had been tampered with? what if the holes were drilled out larger?
I looked at them closely and i think that might be the case. they dont look like a factory hole and some appear larger then others.
does anyone know what size they should be? or where I could get new ones? anyone have 4 they would sell to a poor soul trying to figure out this issue?
I cant imagine that the bike is still running rich with 100 mains and 30 pilots on the second clip!!! it makes no sense!
so there has to be something else wrong with the carbs!
now these jets are from 6sigma jets, they are branded as keihin, so how do they compare to the stock shape and sizes? do they run bigger?
so thats the carburation theory.
now for the compression stuff. Again i had a failed attempt at a make shit leak down tester but, The bike has never had trouble starting ever. in fact as i mentioned before it will start first time on a 3 degree Celsius day everytime because it is so rich.
so lets assume I am getting "good" compression at least good enough for it to run and start.
so what else could be causing a rich condition in this phase. I guess the intake valves could not be sealing all the way or they are opening at the wrong time. this would allow more fuel/air in an cause a rich condition and misfire. also explaining the very dry and black as night soot covered spark plugs, piston heads, valves and exhaust. correct??
i guess this will all be answered with the leak down test.
what else am i missing? what else could be causing such a rich condition with such low settings on the carbs?
Thanks guys,
I hope people still reply after such a long delay.
Jeff
Thanks guys,
Jeff
14 Dec 2014 18:55
Check Pep Boys, Advance Auto, and Auto Zone loaner tool programs. At least one of those stores should have or will order set of leak down gauges that you can borrow for free. Ed
- loudhvx
15 Dec 2014 09:04 - 15 Dec 2014 09:39
I think you should determine if the motor is leaking compression or not, first.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 15 Dec 2014 09:39 by loudhvx.
- Jeff86
27 Dec 2014 11:05
Hey Everyone,
Merry Christmas! I had a very kind gentleman perform a leak down test last week. The engine is not leaking!
The bike is sealing well, there is a chance that the lower compression reading is from the new piston rings not sealing yet or properly because of its short run times and excessive richness.
So I am back to carbs as the main problem. I have smaller jets coming 98's i believe.
I am not on the hunt for a set of carbs. I think the emulsion tubes have been tampered with so I will need new ones, or a whole rack of carbs.
Anyone have a set of emulsion tubes? or a rack of tk22 carbs?
