running out of ideas! kz550a
  • Jeff86
  • Jeff86's Avatar Topic Author
Re: running out of ideas! kz550a
27 Dec 2014 11:10
#657086
Would a set of 84 kz550 carbs work on the 80 kz550? they are TK but not the same as the TK22's on it
  • loudhvx
  • loudhvx's Avatar
27 Dec 2014 12:55 - 27 Dec 2014 12:55
#657096
The throats are bigger on the later carbs, so the manifold mounting screws are farther apart on the later motors. They are too close together, on the early motors, to mount the later carbs.
Last edit: 27 Dec 2014 12:55 by loudhvx.
  • Tyrell Corp
  • Tyrell Corp's Avatar
28 Dec 2014 06:37 - 28 Dec 2014 06:49
#657174
where are you Jeff? I might have some but will have to look for them,
Dumb question but Is your choke working correctly?
Bit of a long shot, but some main jet numbering is different than others...i.e. a 100 main jet could be different sizes between manufactureres. Also some-one may have drilled it out oversize?
www.jetsrus.com/FAQs/FAQ_mikuni_vs_dynojet_vs_keihin_sizes.htm
also lou's informative page:
home.comcast.net/~loudgpz/GPZweb/TK22mai...22jetsAndDrills.html
There seems to be a discrepancy between the two links regarding the kehin / dynojet numbering convention.
Just going 102.5 to 105 made a big difference when tuning my TK's, I noticed one size out you know it, two sizes out and it is virtually unrideable at WOT.
Last edit: 28 Dec 2014 06:49 by Tyrell Corp. Reason: Kehin / DJ numbering convention ?
  • GPzEric
  • GPzEric's Avatar
28 Dec 2014 08:18
#657178
Wow. You've put in some wrench time.
If it were my bike, I'd get on EBAY, buy the airbox, take the carbs back to all stock, put the needle on the middle clip, bump up the main jet to a OEM #94, and I suspect it'd run for you.
Good luck pal !
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • spdygon
  • spdygon's Avatar
28 Dec 2014 10:32 - 28 Dec 2014 10:33
#657189
ill stop messing around and rebuilt the carbs first.....i found the o-ring in my 26mm and 29mm hardand some broken apart not to mention every other o-ring as well.
spent alot of time checking electrical , compresson , etc to find out the carbs were not sealing correctly.
will never mess with a old bike unless i rebuilt crabs and make sure they are working properly.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 28 Dec 2014 10:33 by spdygon.
