Installing Cam Chain Tensioner
  • JimB
  • JimB's Avatar
Re: Installing Cam Chain Tensioner
29 Apr 2014 09:24
#630800
Here is a pic of the alignment
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
The following user(s) said Thank You: Bandit406
  • Bandit406
  • Bandit406's Avatar Topic Author
29 Apr 2014 09:27
#630801
Thanks Jim. I am going to keep looking for a manual but all I am finding is the supplement, and they are very limited info in the supplement . One I seen had a table of contents picture and didnt look like it covered a whole lot.
Strap up them Tanker Boots and Charlie Mike!!!
  • pete greek1
  • pete greek1's Avatar
29 Apr 2014 09:39
#630803
  • JimB
  • JimB's Avatar
29 Apr 2014 09:50
#630805
Here is a pic of the cam chain timing. Before you pull any cams out I recommend you put the tensioner back in and slowly turn the engine via the big nut under the points cover and look to see if the above alignments are correct. Cam cover needs to be removed. Take the spark plugs out and if while you are turning the engine if you feel it stop on something then don't continue you may have slipped a tooth. You might be lucky and may not have slipped a tooth.
  • koolaid_kid
  • koolaid_kid's Avatar
29 Apr 2014 12:49
#630813
You are correct, Martin. The supplement documents the differences between that particular model and the base model. You need the base model and all subsequent supplements leading up to the model you are working on.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • Bandit406
29 Apr 2014 14:05
#630818
Been looking for the Manual I need only one I found is in New Zeland going to keep looking for one here stateside
  • kaw-a-holic
  • kaw-a-holic's Avatar
29 Apr 2014 16:36
#630831
Bandit406 wrote: Been looking for the Manual I need only one I found is in New Zeland going to keep looking for one here stateside
That is where I got my service manual. Cheapest one I could find. Its just a reproduction, great manual.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • pete greek1
29 Apr 2014 16:45
#630832
That's where I got mine, don't know why my e-bay link didn't go thru ,but the only downfall is, the shipping fees, & 4-6 weeks delivery time ...but I love the fact that it's wire bound, & wont close up on the page you're on..Pete
  • pete greek1
29 Apr 2014 16:53
#630833
and the laminated front & rear covers, that you can wipe off if you lay it down on an oily/greasy surface !!!
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
29 Apr 2014 17:41 - 29 Apr 2014 17:44
#630839
That's also the manual I use. But anyway, I would do as JimB says. I would verify timing before tearing out the cams. remove the spark plugs. Just like stated go slow and if you feel any bind stop. But I would just try to go to tdc and stop. from the right side of the motor, the exhaust (front) cam mark should be level with the front valve cover gasket surface on the head. If that's correct, starting at the head surface Skip one pin on the cam chain link. I.E. don't count the pin that the mark is on. Then count 28 pins. that's where the timing mark on the intake (rear) sprocket should end up. If that's where it ends up then its in time. If any of the marks are off its out of time. You can also look at the cam lobes on the number 4 cylinder. With it at tdc the cam lobes will be facing towards each other and will be perfectly level with each other. If the lobes face away from each other, ur at bottom dead center. But you can still look and see if the lobes look exactly the same position. Hope that helps.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 29 Apr 2014 17:44 by Powerstroke_fan.
  • Powerstroke_fan
29 Apr 2014 18:04
#630843
I just put my motor back together today. So I just went out and snaped a few shots to help you verify timing. This can be done with out a manual.
Attachment IMG_0501.jpg not found
Here is the exhaust cam timing marks. See how it is flush with the top of the gasket surface. I know your marks will look different, Mine is a dot since there aftermarket sprockets. I put a blue dot on the pin on the cam chain to help show where the dot is.
Attachment IMG_0502.jpg not found
Here is where the intake timing mark lines up.
Attachment IMG_0503.jpg not found
See how the lobes are level with each other, and facing each other,
Attachment IMG_0508.jpg not found
Here is the timing advancer marks lined up with tdc for 1&4
Attachment IMG_0507.jpg not found
Heres a close up of it. Hope this helps.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
  • martin_csr
  • martin_csr's Avatar
30 Apr 2014 06:02 - 30 Apr 2014 06:27
#630890
Bandit, powerstroke's upper cam roller has been removed, obviously, but don't remove yours.
I don't think you would have, but just in case. :)
Last edit: 30 Apr 2014 06:27 by martin_csr.
