Installing Cam Chain Tensioner
- Bandit406
27 Apr 2014 12:04
Hey guys New to the site here and complete Newbe to bikes. Was trying to get the breather box back on my 1980 KZ1000 Ltd and in the process to make more room I took off the cam chain tensioner, not knowing what it was....
So I have been trying to find what the proper procedure is for re installing it. I found a link to a Manuel and was reading that to install it the push rod should stick out about 7.5 mm.
So my question is do i just turn over the engine by hand until the push rod is at the 7.5 mm point and then finish securing the tnsioner body? Really don't want to mess this up. the bike was a gift from my father and only has 28,000 miles on it. sure would hate to damage it before even getting to enjoy riding it.
Thanks in advance for any help you guys can give me.
Strap up them Tanker Boots and Charlie Mike!!!
- havakaw
Re: Installing Cam Chain Tensioner
27 Apr 2014 12:37
Welcome. DO NOT TURN THE MOTOR OVER AT ALL WITH OUT THE TENSIONER IN IT!!!!!!!!!!!!!!!!! If all you did was just remove it ti get at the air box,you should be able to re-install it without a MAJOR problem.remove the big cap-nut before you reinstall it. That will allow the tensioner to slack back.Once it is tightened up to the jug,then install the cap-nut. That will set the tensioner back right. Good thing you asked first.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
The following user(s) said Thank You: Bandit406
- Bandit406
27 Apr 2014 14:24
Ok well I am hanging my head in shame..... This was taken off about a year ago and I had a buddy helping me. He said we needed to turn it over by hand with the kick start very easy until it would seat again. After reading your reply I am concerned I just made a big mistake, or cause me a bunch of work that did not need to be. What do I need to do now in order to put it back together? Again thanks in advance I really appreciate your input.
- Bandit406
27 Apr 2014 16:53
so after more reading I am assuming that I have jacked the timing up? Anyone know if that is accurate?
- Powerstroke_fan
27 Apr 2014 17:39
You could have I would install the tenisor, then remove the valve cover and verify your timing.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
28 Apr 2014 06:35 - 29 Apr 2014 06:01
I bet the timing mark on the timing advancer is not aligned w the engine timing mark.
So my guess is that he should not turn the crankshaft to check the timing???
To be safe, should he remove the camshafts etc & set the timing from scratch?
Last edit: 29 Apr 2014 06:01 by martin_csr.
- Bandit406
28 Apr 2014 07:28
Yeah I think I am calling a few of the shops this morning and its going to them. In over my head... Thanks Guys really appreciate it.
- koolaid_kid
28 Apr 2014 07:31 - 28 Apr 2014 07:34
Before you take it to them, pull the cams. This will prevent them from attempting to rotate the engine with the cams still in place.
This is what needs to be done:
Pull the cams.
Rotate the engine until it is at the mark. For setting the cams, I believe it needs to be at TDC.
Install the cams, one at a time. IIRC, the intake goes first.
Set them correctly, in accordance with the Factory Service manual.
Then you should be GTG.
Pull the cams.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Last edit: 28 Apr 2014 07:34 by koolaid_kid.
- pete greek1
28 Apr 2014 09:42
Make sure you use a wire, or coathanger to hold up the chain, so it doesn't fall into the crankcase when removing the cams
- Bandit406
28 Apr 2014 10:29
So if I dive into this will also need to get a valve cover gasket and the cam end caps correct? I think I will go ahead and try this myself. It has set this long already so if it takes me awhile oh well, i think it will be a good lesson for me and what better way to learn about my bike then fixing it myself!!! Really appreciate all the reply's and input THANKS GUYS!!!
- pete greek1
28 Apr 2014 10:41
If your valve cover isn't leaking, & you don't tear/rip the gasket when removing cover, you can reuse the gasket
Pete
Pete
28 Apr 2014 10:55 - 29 Apr 2014 06:50
With the correct factory manual & a digital camera, internet photos & youtube videos, plus KZRider help, this seems like it ought to be doable.
Before taking it some place, maybe remove the right side engine cover & remove the pulsing coil (just let it hang down), then take a good photo & post it. You could do the same w the valve cover: remove the fuel tank, coils, & clean air system stuff above the engine, then the cover & take a pic. This would be a good start. Most of that should've been fairly straight forward, if not easy. Then you could put it back together if you don't think you'd want to proceed.
(note: there is a handy way to remove the valve cover with a decent chance of preserving the gasket).
(note: I use a hand impact driver to remove the engine cover bolts/screws to keep from messing up the heads).
Last edit: 29 Apr 2014 06:50 by martin_csr.
