Need help please
- Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- MDawnz1
- Thank you received: 27
2 questions:
What brand of plugs ?
And
Are you using some kind of anti-seize on them?
My bike HATES NGK plugs.
Many if not most of the bike I have worked on ran MUCH better with ND hot U's.
With no other change at all.
I have been trying to figure out why for 35 years.
1974 Z1a, still 903
- Thank you received: 2829
MDawnz1 wrote: Very happy to hear it's fixed.
2 questions:
And
Same with my bike. Ed
- Schmeck
- Thank you received: 2098
Might be oil fouled, or fuel fouled, or other visible indication as to reason for plug failure.
Going more than one range hotter than FSM recommended spec is ill-advised.
- Schmeck
- Schmeck
Schmeck wrote: To answer your question ed, when the bike eats the plug it doesnt work . Fouled, or whatever else a plug does. I know when the plugs are dead because the bike will refuse to accelerate and die whenever I crack the throttle. Once I put new plugs in it the bike comes to life again .
If you can post close-up pictures of one of the plugs that is bad it might help. If the plug is black and oily it is oil fouled; if wet and smells like gasoline it's fuel fouled; if it is dry but has tiny gray specks on the the insulator and electrodes or if the insulator is abnormally bright white it may be running too hot. Some guys (not me) on this site can read a plug like a book, so if they see pictures they may be able to provide more insight. Ed
With an uninstalled new plug connected to the cap and its base held grounded against the engine head, what is the visible spark quality when the engine is cranked over with the ignition switched on?
Supposed to be fat blue sparks -- not weak orange sparks.
Poor spark may promote early plug failure by failing to keep the combustion residue burned off.
Has ignition timing been verified with a strobe type timing light to assure the F mark aligns with the case mark at idle rpm? Not the T mark; not the letter T; not the letter F.
Incorrect timing usually results in reduced power.
Has proper timing advancer function been verified with a strobe type timing light by watching the advancer move quickly back and forth as rpm is varied by blipping the throttle?
The advancer may require lube, or both cleaning and lube.
A hanging advancer usually results in performance issues, including reduced power, over-heating, etc.
If not already done, would perform compression tests, both wet and dry; and also assure valve clearances are within specs.
Too tight valves may allow decent performance by a cold engine, until the engine warms and begins losing compression as the valves begin leaking.
- Schmeck
- MDawnz1
Sure maybe you can turn the choke off,
but big deal,,,,,
The plugs have to get HOT to self clean them selves.
That is like a half step down from turning it into a diesel (pinging & knocking)
I know for a fact it takes a 900/1000 30 minutes of riding time to get to temp.
If the book calls for B8ES plugs,,,,,use them and tune the bike to them if you have to,,,,,
If you want to try ND's it.s W24ES-U
1974 Z1a, still 903
