Need help please
Re: Need help please
31 Aug 2013 15:53
#604156
I've never seen a KZ with a fan, but in DC the cops have fans mounted on their Harleys because they spend a lot of timing sitting at lights blocking traffic when they are doing escort duty for the bigwig politicians. Ed
  • Schmeck
  • Schmeck's Avatar Topic Author
31 Aug 2013 17:38
#604173
I was looking at fans ,only, alot of them are plastic. I would imagine the hot head pipes would cause this plastic to warp if it was close enough. Again though, it was an idea :) Thanks
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • MDawnz1
  • MDawnz1's Avatar
01 Sep 2013 03:10
#604252
I thing he was recommending a high power fan that sits on the floor.
Like you use on a dyno.
NOT one to wire onto your bike. :laugh:
Mike
1974 Z1a, still 903
01 Sep 2013 09:38
#604278
You are correct; that is what I meant. I may have worded it poorly. Ed
  • Schmeck
01 Sep 2013 13:01
#604301
Nice, So i checked the plugs after running it a couple times around and they seem to be holding up nicely . Now I just have to deal with the brake issue In my other post . Thanks guys for the help and info on Fans lol
  • Schmeck
02 Sep 2013 17:57
#604509
Just went for a ride, and power was gone :/ checked spark plugs, glossy black like wet black. Cleaned them off and put them back in a no change. Its still killing plugs. This time it was the ngk B8ES plugs. Can I put a bigger fuse in to let more power through? My ignition is a replacement, maybe I should try putting the original one back on. Fuel levels seem fine it runs at the 1 on the rpm guage so that's good. Plug has a funky smell of gas. I would ask whats the hottest plug I can run but I have a feeling it will just kill the new plugs too. This is getting irritating,
  • Schmeck
02 Sep 2013 18:05
#604512
Could it possibly be oil-fouled? I mean It has a funky smell so its hard to tell If its gas or oil. I want to say it smells like gas,
