Need help please
  • Schmeck
  • Schmeck's Avatar Topic Author
Re: Need help please
30 Aug 2013 11:41
#603913
thanks for the ND plug info and you might be right . this is one of the new plugs I pulled that i ran yesterday. Bike was set around the 1 on rpm guage where it should be .
Attachment image_2013-08-30.jpg not found
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • Schmeck
30 Aug 2013 12:49
#603921
I didnt find ND at my local store but they have a brand called Denso? Could this work and what number plug they have alot of different ones . I need a hotter plug
30 Aug 2013 14:27 - 30 Aug 2013 14:32
#603930
Schmeck wrote: I didnt find ND at my local store but they have a brand called Denso? Could this work and what number plug they have alot of different ones . I need a hotter plug
Nippondenso shortened their corporate name to Denso in 1996. You may find spark plugs marked ND or DENSO, they are from the same company. As MDawnz1 said, the Denso (ND) W24ES-U plug has a heat range equivalent to the B8ES plug. The next hotter Denso plug is the W22ES-U. Ed
Last edit: 30 Aug 2013 14:32 by 650ed.
  • Schmeck
30 Aug 2013 15:34
#603941
okay kool, well in the havock of traffic near my house I decided to just grab some b8es plugs since I had to go out today. Will see how they run and check them when they cool down . learned my lesson about taking out hot plugs.
  • MDawnz1
  • MDawnz1's Avatar
30 Aug 2013 18:53
#603975
OK, the NEW part# is,
Denso 4030 W24ES-U
sparkplugs.com has them in stock.
And yes they are getting harder to find.
Everyone (the company's) are making plugs that last 100,000 miles in a car because they HAVE to.
What about us?
And that photo of your plug,
That never even got close to operating temperature.
1974 Z1a, still 903
The following user(s) said Thank You: bluezbike
30 Aug 2013 20:56 - 31 Aug 2013 01:48
#604003
Schmeck wrote: ... plugs are usually pitch black and dry. I usually clean them off and try them again and they would end up the same way. I think its just the plug but I will post pictures tomorrow of what the old plugs look like and what my new plugs look like since I have 2 rides in so far on them. Only 5 minute rides around back roads but still counts since Im a crack the throttle kind of rider. Ill also will see about getting those other plugs instead of ngk. -Tyler
Imo, spark plug brand isn't relevant to the reported issues.
See my earlier post.
Good Fortune! :)
Last edit: 31 Aug 2013 01:48 by Patton.
  • MDawnz1
  • MDawnz1's Avatar
31 Aug 2013 01:24
#604076
Patton.
You are right about a basic check of the system,
BUT he only runs the bike for 5 mins. at a time.
1974 Z1a, still 903
  • Schmeck
31 Aug 2013 13:30
#604143
Sorry for the incorrect information, I usually only ride it for 5 minutes at a time because the bike is not legal around my area just yet. I do however let the bike idle for 15-20 minutes while Im cleaning stuff up. So far These B8ES plugs are working great. I will try the Denso 4030 plugs also when Im out and about. On another note, I have went through the system numerous times trying to make sure everything is as right as I can get it. Thanks for the help so far, Ive really learned a lot since Ive been on kzRider. Im also wondering, what do you all usually run in ur gas? Im running 93 just because I feel its better for the motor.
31 Aug 2013 13:57
#604145
These are air cooled engines. Letting them idle for 15 - 20 minutes in the summer is deadly to them unless you are running an industrial size fan on them. I HIGHLY recommend you stop that practice before you destroy the engine on your bike.
I use 93 octane and it works very well in my bike, but I believe most folks use 87 or 91. Ed
  • Schmeck
31 Aug 2013 14:33
#604147
I usually have it idling in my garage where its nice and cool. I noticed it was air-cooled when I first bought it :laugh: These engines run hot the minute I start it. So I can agree that the summr heat would probably kill it if it hadn't been ventilated. I don't own an industrial size fan but if I ever get the idea to buy one my local tractor supply has plunty of them. Love that place
31 Aug 2013 14:41
#604148
The garage being cool or ventilated really is not sufficient to cool the engine. The fins are engineered to cool the engine by dissipating the heat to air passing across them. So when the bike sits still the heat will build up, especially in those areas which are somewhat enclosed because fresh, cool air is not moving across the fins to draw the heat away from those areas. It's your bike, so do as you see fit, but I just thought you might like to know how it works. Ed
  • Schmeck
31 Aug 2013 15:42
#604154
Thanks Ed, I probably should be alittle more careful with it. Have you ever heard of someone putting a fan on there bike? I don't know how much good it would do, but it must be better than not having one. - Tyler
