- Thank you received: 2
What does this mean!?!?
- donthaveakawman
- Visitor
- treitz
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- treitz
I can set the float to 0mm or level and it flows fine. Causing the bike to run rich. But if I adjust it at all, fuel will only flow without the bowl snugly tightened. Once I tighten the screws, fuel flow completely stops.
- Thank you received: 2098
The air screw affects mixture throughout pilot circuit range, not just at idle rpm.
And just for grins, would assure the float mechanism isn't installed upside down.
- Nebr_Rex
- Thank you received: 300
treitz wrote: After further testing, I think my carb might be malfunctioning. I think my float bowl is actually pushing my floats up, closing off fuel flow.
Have you checked your bowl vent?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- steell
Is the float upside down in the float bowl? You can do that when reassembling some carbs.
- treitz
- donthaveakawman
- Visitor
little carb/big exhaust equals foul plugs=lean
- treitz
donthaveakawman wrote: big carb/little exhaust equals foul plugs=rich
You might be right. I may need a more open exhaust.
Turns out my float actually was not upside down. I am having a hard time finding that 3mm sweet spot. But I did get adjusted leaner. So I'll run it tomorrow to see if its too lean. If it is, then I at least know that my float height is the culprit here.
- treitz
- steell
Are you getting a healthy blue spark? And are they the right heat range plugs?
And is the timing correct? And? And? And?
Must be the meds :laugh: :laugh:
- treitz
steell wrote: If you make a bunch of changes in the carb and it has no effect on the plugs, maybe it's not a carb problem?
I did check the timing last weekend, and the spark looked strong. I can double check though.
I'm almost positive the carb just isn't working right. It's almost like the floats are hitting something so they wont move freely or something. I think I'm going to just take it to a shop and have them bench test it.
