What does this mean!?!?
- treitz
28 Mar 2013 21:15
Bike is running well (not acting rich or lean) but my plugs are still telling me its rich.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- undiablo
Re: What does this mean!?!?
28 Mar 2013 22:13
May be you should try a hotter spark plug.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- taildragger1197
28 Mar 2013 22:47
Dirty air cleaner
Leaving choke/enricher on too long
Excessive time idling
Pilot jets too big/screws not adjusted correctly
Take the bike for a 10 mile ride at highway speeds then check your plugs. NOT after you have just started it up and have been idling.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
28 Mar 2013 22:52Valve clearances within specs?treitz wrote: Bike is running well (not acting rich or lean) but my plugs are still telling me its rich.
Fat blue sparks visible on plugs?
Ignition timing spot on?
Advancer functioning properly?
Over-rich mixture from carb (for whatever reason).
- 893cv
28 Mar 2013 22:57
You may need to check the voltage at the ignition coils. It needs to be the same as battery voltage. If it is low, clean all of the connections between the battery and the coils. The kill switch on the handlebars and the main (key) switch are problem areas due to being exposed to h2o. When the ignition system is operating with full voltage you will not see any soot on the plugs.
I have installed the "coil mod" on all of my bikes. You can do a search for more information.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- treitz
28 Mar 2013 23:15 - 28 Mar 2013 23:17
I did the coil mod already.
I'll check the other things you guys suggested.
I'm hesitant to take it on a long ride for fear that I'll burn my plugs up running rich for whatever reason.
My compression is low, could that be the cause?
Last edit: 28 Mar 2013 23:17 by treitz.
28 Mar 2013 23:38treitz wrote: I did the coil mod already.
burn my plugs up running rich -- not likely, but might foul them out.
My compression is low, could that be the cause?-- Yes, but sometimes resolved by adjusting valve clearances to specs.
Would pull the plugs and look for fat blue spark while spinning the engine. Plugs will be otherwise connected as usual, and held grounded against the engine head. Ignition must be switched ON.
28 Mar 2013 23:40
Did adjusting the valve clearances improve compression?
What is visible quality of the spark?
- treitz
28 Mar 2013 23:43
I tried adjusting my valves but couldn't figure it. Still working on that.
I'll check the quality of my spark tomorrow.
- treitz
31 Mar 2013 11:45
Valves are correctly set.
Reset timing to factory settings.
Getting good spark.
Retested compression and its not low after all! So happy.
Plugs are still black.
I guess it's back to jetting?
Getting good spark.
31 Mar 2013 13:24
As suggested by taildragger1197, check for dirty air cleaner.
If not already done, would next perform clear tube tests, to verify the service fuel level. If too high, will overly enrichen carb circuits
What carb cleaning has been recently done?
- baldy110
31 Mar 2013 17:20
You are putting in new plugs every time you read them right?
