Cylinder head removal and valve question
- Spenzher
'83 KZ750N Shaft
- wireman
- Thank you received: 299
If it were me Id go ahead and check all the guides and do new seals while youre in there,Id also have all the other seats and valve faces checked while youre in there
- Spenzher
wireman wrote: How many did you ding?
I'm not sure yet, all I know right now is that I'm getting zero compression in the one cylinder I worked with, and before it was working 100%. Hell, even with the torn spark plug threads I was getting 80psi. I suppose its perfect timing to learn how to check them so why not
'83 KZ750N Shaft
- bountyhunter
- Thank you received: 337
I would definitely get the head done when it's off, air cooled engines wear the valves and seals quickly. Put in some VITON valve seals.
- Handcannon
- Spenzher
bountyhunter wrote: You can absolutely take the head off without pulling the motor and the cylinder too if need be.
Great. I'm going to start removing the head today, wish me luck.
'83 KZ750N Shaft
- Spenzher
'83 KZ750N Shaft
- bountyhunter
My old 750 was fouling plugs every ten minutes before I overhauled it. Removed the plugs hot at least 100 times with no problem to put in the spare set so I could get home.....Spenzher wrote: Ouch so I didn't quite get all the shavings out. I think I used too much grease when grinding out the new spark plug hole because there was like a mucus of little shavings around the piston and on top of the combustion chamber ceiling. So I tested the valves and the intake is the one leaking. I'm not sure if it is because of shavings or I actually bent it, but I'll find that out tomorrow when I get it out. I'm also getting worried that the piston rings might be carrying some grainy shavings, so the cylinder block may be coming out too. Next time if I did this again I think I would use less grease and allow the shavings to come through dry(er). I was reminded on another forum that I shouldn't have taken out the spark plug while the engine was warm.
- bountyhunter
That would concern me too.Spenzher wrote: I'm also getting worried that the piston rings might be carrying some grainy shavings, so the cylinder block may be coming out too.
- 3cav84a
1977 KZ 1000 A1
- bountyhunter
- wireman
I think of it in terms of youre already inside of the motor,why not check it all now and buy yourself many more years of trouble free service out of it.Spenzher wrote:
