- Thank you received: 6
More bad news.
- badrhino
21 Mar 2013 16:16 #578016
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Replied by badrhino on topic More bad news.
Franken Z!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- Thank you received: 20
21 Mar 2013 16:30 - 21 Mar 2013 16:31 #578018
by newOld_kz1000
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Replied by newOld_kz1000 on topic More bad news.
If it's me I'm pulling the cylinder, clean the pistons, measure the bore, maybe new rings, do the valves. If you have a valve spring remover, you're good to go, you can 100% with certainty check the valve seat and the valve.
If you're not $$ able to do it, you can at least clean stuff up and beg a bike mechanic to check your valves and seats as a side job, so he won't have to charge you the shop rate (people wonder why the shop labor rate is high, it's because of the 'overhead' of running the business, and with a guy doing the wrenching work on the side, he has no such 'overhead' like making payroll, rent, insurance, yada yada and can charge a lot less.)
Whatever you do, verify with 100% certainty before reassembling that you found the source of the leak.
If you fool yourself into thinking the very first thing you find is the cause -- and you're wrong -- you have to be very thorough when troubleshooting -- if you reassemble and still have the issue, this might happen
Last edit: 21 Mar 2013 16:31 by newOld_kz1000.
- slayer61
- KZR FLAG RELAY CARRIER #62
21 Mar 2013 17:31 #578023
by slayer61
Monty Python "twit of the year" Now THAT was some funny shit!
Replied by slayer61 on topic More bad news.
- donthaveakawman
- Visitor
21 Mar 2013 18:13 #578031
by donthaveakawman
Replied by donthaveakawman on topic More bad news.
- SlowRide
22 Mar 2013 11:07 - 22 Mar 2013 11:11 #578124
by SlowRide
Replied by SlowRide on topic More bad news.
Looks like a timesert in the sparkplug hole. Also looks like a chunk of carbon is holding that valve open. The margin looks aweful small on them, they may have been worked in the past and are at their limit now.
Get those valves out and clean the seats and bead blast the valves.
Last edit: 22 Mar 2013 11:11 by SlowRide.
