- Thank you received: 6
More bad news.
- badrhino
Compressions:
1: 120
2: 110
3: 40
4: 120
Yeah number three is bad. What do you suggest I do now? Should I recheck the valves to make sure they are still good? I don't know how it would have gotten off. Could the timing be off? But wouldn't that affect all cylinders if that was the case?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- wireman
- Thank you received: 299
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
- badrhino
Franken Z!
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- lushbaugh
- everybodys a pro......
- Thank you received: 35
Powerstroke_fan wrote: I would check the valve clearance. Then if all is good i would perform a leak down test.
yep
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- steell
yep
Yep
- donthaveakawman
- Visitor
spray some carb cleaner in the intake valves and see if it leaks past them.badrhino wrote: No I did not have the throttle open on any of the readings as the carbs are not on at the moment.
- wireman
Attachment stewie_2013-03-04.jpg not found
:laugh:
- lushbaugh
:laugh:
- donthaveakawman
- Visitor
