- Thank you received: 6
More bad news.
- badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- badrhino
Franken Z!
- wireman
- Thank you received: 299
- zukdave
- Thank you received: 229
badrhino wrote: Bump........is it time for a head job?
Always time for one
Sometimes the bike needs one too.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- donthaveakawman
- Visitor
23 dollars, I could put that in the air cleaner box and watch the carbonators for that price.newOld_kz1000 wrote: You use a Hogan's Heroes miniaturized camera to check them valves and seats -- only tricky part is getting the dang thing in position inside the bore
THE CAMERA IS SMALLER THAN A 9-VOLT BATTERY only costs $23 on Ebay
- it is a color camera
- it has audio as well
- resolution is only 380 tv lines (TVL) but shouldn't matter if you're up close
On the more expensive side, $150 for this one, it is smaller than a peephole you find in the front door of a house, to help you figure out if the valve seats are burned (= leaking valve seat) or maybe avoid pulling the head again is this guy
- 4000 (thousand) TVL -- very very high resolution, super clear images
- 15mm in diameter
- 180 degrees view angle.....wow. Only $150.
The generic peephole mounted in doors is on the left in this picture, the camera's on the right -- tiny
This one's a Sony, gotta be good, and only $53, look how tiny it is, smaller than an RCA jack in the picture there
- 420 TVL of resolution
I've been debating getting one or 2 of these to see if it makes my life easier, I have a kz900 right now with a compression issue, I alos have a Honda Nighthawk that might have thrown a small-end bearing and was gonna put a small camera down there to see if the piston drops or is there 'play' as I rotate the crank.....
stuff like that. Lots of reasons to want a tiny camera inside sometimes.
Search on "mini camera" on ebay, lots of 'em.
If you burned a valve seat (running lean? is your exhaust pipe blueing on that low-compression bore? maybe it ran too hot and scorched that exhaust valve seat; are you running individual pod filters and a less-restrictive pipe and did you re-jet for that?)
I gotta stop procrastinating, get me a tiny camera like the one my dentist uses to scare me into getting more fillings and other works. Lots of reasons to have a tiny camera in the engine sometimes.
They're cheap too, the first time a mini camera saves you from a tear-down of the motor, it has paid for itself.
should have got a v8.badrhino wrote: Bump........is it time for a head job?
- wireman
Always time for one
- badrhino
Franken Z!
- donthaveakawman
- Visitor
- Thank you received: 2098
- Old Man Rock
- Thank you received: 225
1) Remove exhaust.
2) Remove spark plugs
3) Ignition plate cover off.
4) Using larger crank nut (not smaller), rotate crank where cam lobe is not pressing against shim thus opening valve.
5) Small pen light down spark plug hole into chamber.
6) Look into exhaust port...
See light...?
Yup, bent valve or spring or.... regardless, head has to come off for further inspection/valve job.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- badrhino
Franken Z!
- badrhino
Franken Z!
