- Thank you received: 35
oil leak
- donthaveakawman
- Visitor
get a valve clearance feeler guage at the auto parts store and that would put you at about 25.00 total. plus shipping.wireman wrote: Start with a valve cover gasket from z1enterprises,they got it listed for $17.41.
Attachment DSC05835_small.jpg not found
You can also clean up cam end plugs at same time and glue them back in with some 3bond on the bottem side before installing valve cover gasket.
- lushbaugh
- everybodys a pro......
if you give advice thats a joke try to state that man. dont need someone destroying kaws for your amusement, do that stuff on harley forums lol. and that copper coat is good stuff wireman like i told you on the phone i got hooked from my dad using old indian head copper gasket shillack.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
- Visitor
- natetru
- Thank you received: 2
1982 kz1000 m2 csr
- donthaveakawman
- Visitor
- natetru
- KZJOE900
- Admin
natetru wrote: Did powder check...definitely a head gasket and also leak on back side of motor will kno what to call the part when my manual arrives, but it is a small 2 bolt flange that mounts to the motor and one to tranny......so i will start ordering gasket parts...... while im there valve check.... what else? Thanks
The one mounted on the cylinder block is the cam chain tension adjuster. The one on the behind the in to the base is the oil pressure switch (wire should be connected to it). Those are easy fixes.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- natetru
1982 kz1000 m2 csr
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
- natetru
1982 kz1000 m2 csr
- donthaveakawman
- Visitor
