oil leak
  • natetru
  • natetru's Avatar Topic Author
Re: oil leak
10 Feb 2013 21:01
#571793
Cleaned and dryed the cases, sprinkle powder all over, then started motor and looked to see where the oil tracked the powder.......also washed the motor 4 times this week trying to figure this out and now milky oil in sight glass....so dropped all the oil and going to remove filter and get it all cleaned out....
1982 kz1000 m2 csr
  • natetru
Re: oil leak
10 Feb 2013 21:06
#571795
Veshrah and athena brand gasket kits on ebay.....either one better or stay away from both?
1982 kz1000 m2 csr
  • donthaveakawman
  • donthaveakawman's Avatar
Re: oil leak
10 Feb 2013 21:07
#571796
I think you are right, I have a similar oil leak and no compression on the #2 cylinder even with oil in there.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: oil leak
10 Feb 2013 21:41
#571804
Once you know you got good oil on there, the sight glass will get milky looking if you dont go for short rides. The motor doesnt get up to temp long enough to let the motor evaporate the moisture.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
The following user(s) said Thank You: wireman, natetru
  • natetru
Re: oil leak
10 Feb 2013 21:48
#571805
Any advice on a gasket kit and if all the kz1000 tach seal kits are the same? Thanks again
1982 kz1000 m2 csr
  • wireman
  • wireman's Avatar
Re: oil leak
10 Feb 2013 21:48
#571806
My secret for sealing any paper gasket no matter who its made by,dont use on head gaskets (unless theyre copper,yours wont be)
Attachment coppercoat.png not found
B)
  • natetru
Re: oil leak
10 Feb 2013 21:57
#571812
Stupid question....how exactly do you use this along with a paper gasket? Thanks
1982 kz1000 m2 csr
  • wireman
  • wireman's Avatar
Re: oil leak
10 Feb 2013 22:01
#571813
Spray down both sides of paper gasket and let it tack up before installing gasket B)
The following user(s) said Thank You: natetru
Re: oil leak
10 Feb 2013 23:10
#571842
Would check with www.z1enterprises.com/
Good Fortune! :)
  • wireman
  • wireman's Avatar
Re: oil leak
11 Feb 2013 00:00
#571864
B)
does that help for piston rings?
Sure,after you replace the rings use this stuff on the new gaskets! :woohoo:
The following user(s) said Thank You: KZ250LTD
  • natetru
Re: oil leak
11 Feb 2013 07:49
#571902
Good Fortune! :)
Patton- when i put my specific model in they do not show a gasket set or tach seal kit.....what am i missing?
1982 kz1000 m2 csr
  • Powerstroke_fan
Re: oil leak
11 Feb 2013 08:39 - 11 Feb 2013 08:40
#571904
If its a cable driven tach. then i think they are the same 77-80 kz 1000s. They quite using cable driven tachs in 81 or 82 so not sure what yours has.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 11 Feb 2013 08:40 by Powerstroke_fan.
