- Thank you received: 1556
PMFR clutch release, KZ1000
- donthaveakawman
- Visitor
26 Jan 2013 23:36 #569435
by donthaveakawman
Replied by donthaveakawman on topic PMFR clutch release, KZ1000
1 / 1
Roller Clutch Push Rod Kit
APKCB900
Replaces the stock clutch pusher 'mushroom' - eliminates risk of welding clutch push rod to the mushroom when pulling the clutch in at high speed.
APKCB900
- zed1015
27 Jan 2013 11:00 - 27 Jan 2013 11:37 #569489
by zed1015
Replied by zed1015 on topic PMFR clutch release, KZ1000
I usually make my own outriggers etc from scratch but i have just bought a complete new PMFR cluch release at such a bargain price that it really was cheaper than buying the materials for making my own.
If you still need the spacer measurements in a week or so i will post them here when the postie has been.
As for this statement.
The ball bearing is in the input shaft and cannot escape without removing the clutch pusher.
Sorry but that is wrong.DoubleDub wrote: DO NOT REMOVE THE PUSHROD AS THE BALL BEARING AT THE CLUTCH SIDE CAN FALL INTO THE ENGINE.
Last edit: 27 Jan 2013 11:37 by zed1015.
- zed1015
27 Jan 2013 11:14 #569491
by zed1015
As Doubledub stated previous.
That is the Roller clutch pusher that utilises a clutch pusher (mushroom) faced with a radial bearing which runs against the pressure plate to reduce friction.
Under normal circumstances the ball bearing between the pushrod and mushroom does the job just fine but under extreme load ,high rpms and hard launches on mainly drag bikes the ball can friction weld to the pusher, pushrod or both.
donthaveakawman wrote: 1 / 1
APKCB900
