exhaust valves crappy what how to clean them
Re: exhaust valves crappy what how to clean them
16 Jan 2013 16:54
The topic has been locked.
- wireman
16 Jan 2013 17:41Attachment stupidometer.gif not found
:woohoo:
- donthaveakawman
16 Jan 2013 18:49DoubleDub wrote:donthaveakawman wrote: puts the lotion on the skin, whatever. how many times do I have to replace my gaskets?
8, or they won't seal properly.
Iso heet seems to eat gaskets pretty quick, it's got cleaner in there. strange that I adjusted my floats pretty evenly, but when i checked them I was surprised, i think someone snuck in there and tuned them up for me.
16 Jan 2013 20:09 - 16 Jan 2013 20:11LOL. I thought it was a laugh meter... wrong.wireman wrote:Attachment stupidometer.gif not found
:woohoo:
donthaveakawman, are you sure the tap tap tapping isn't the valves. They do make a bit of noise.
Last edit: 16 Jan 2013 20:11 by martin_csr.
- donthaveakawman
16 Jan 2013 22:21
very well could end up like my vw with a valve stuck through a piston, who knows.
- donthaveakawman
16 Jan 2013 22:25 - 16 Jan 2013 22:25
may end up plugging the clean air vacuum hose outlets and see if it does the tapping then. also i want a regular petcock.
Last edit: 16 Jan 2013 22:25 by donthaveakawman.
- DoubleDub
- donthaveakawman
17 Jan 2013 19:24 - 17 Jan 2013 19:33
trying to upload my new video, sounds better with an oil change. tick tick tick, usually goes away after it has been running for a while. bear with me.
this video is awesome
Last edit: 17 Jan 2013 19:33 by donthaveakawman.
- DoubleDub
18 Jan 2013 22:27
Pretty sure you have a worn rod bearing. Probably going to throw out soon. Better sell me the bike so I can rebuild it.
- wireman
18 Jan 2013 22:36Attachment troll.gif not found
- DoubleDub
18 Jan 2013 22:41wireman wrote:Attachment troll.gif not found
:blush: My bad.
- donthaveakawman
26 Mar 2013 01:51 - 26 Mar 2013 02:01
I took the exhaust back off the engine to make sure it isn't leaking and the valves are like christmas, I will get some photos asap but they do not do justice to what I am seeing here.
it appears as though it were similar to a powdered doughnut.
Last edit: 26 Mar 2013 02:01 by donthaveakawman. Reason: extra
