exhaust valves crappy what how to clean them
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
Re: exhaust valves crappy what how to clean them
09 Jan 2013 05:04
#566502
maybe some kerosene in the clean air duct?
The topic has been locked.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
09 Jan 2013 05:50
#566504
donthaveakawman wrote: maybe some kerosene in the clean air duct?
What do you think Seafoam is?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • donthaveakawman
09 Jan 2013 06:01 - 09 Jan 2013 06:04
#566506
isn't that the stuff with the white whale on the label?
Attachment Dr-hannibal-lecter-94577863011.jpeg not found
Last edit: 09 Jan 2013 06:04 by donthaveakawman.
09 Jan 2013 10:06
#566518
  • Motor Head
  • Motor Head's Avatar
09 Jan 2013 10:39
#566521
bountyhunter wrote: Not that anybody asked, but that buildup is normal. I wish mine were that clean. If you really want to see a bunch of carbon crud, you should see whats on the inside surfaces of the valve faces and head.
What cleans it: the machine shop drops the head into something affectionately known as a "hot tank" which is filled with bubbling heated chemicals..... and you will notice nobody putting their hand in there. :ohmy:
If the valves are free you can soak them in Chemdip and take a stiff nylon brush to them.
Thats pretty much normal deposits for these motors over time. I'd be Much more worried about the valves themselves are seating/ sealing. Then if they leak, are the clearances correct? If they are OK and the valves leak, then you have a reason to pull the head off. If those valves are pitted deep enough, worn, etc, you'd be replacing them as part of a valve job. Otherwise don't waste to much effort on a bit of deposits.
  • martin_csr
  • martin_csr's Avatar
09 Jan 2013 12:10
#566529
Berryman's B-12 Chemtrol is another cleaner-type product.
I would do what MotorHead & others say and do the valve clearance & compression checks.... the checks are easy.
  • donthaveakawman
09 Jan 2013 17:25
#566577
In the gas tank right? I am not messing with a bunch of t-fittings. this is mainly because the the valves won't close if they are too gummed up.
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
09 Jan 2013 19:38
#566613
gastank , oil, and or fog the intake with it in a squirt bottle.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • donthaveakawman
09 Jan 2013 21:47
#566632
isn't that what spray carburetor cleaner does? 4 bucks a can vs 10. :huh:
  • donthaveakawman
09 Jan 2013 21:49
#566633
I put it back together last night, going to have to leave the crashbar off there and be careful because it is tighter than snug with these pipes. I'll take a picture when I put the daytona handlebars on there. crap I need to drill a hole for the throttle.
  • DoubleDub
  • DoubleDub's Avatar
10 Jan 2013 13:51
#566701
:huh:
  • turboking
  • turboking's Avatar
10 Jan 2013 14:36
#566706
I'm a seafoam believer B) ........... I use it in everything that takes fuel :woohoo: ........
my current stock for me.
Attachment DSCF1580Small.JPG not found
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
