exhaust valves crappy what how to clean them
Re: exhaust valves crappy what how to clean them
11 Jan 2013 14:03
Im sure he will self destruct again
Mods will tire of complaints and pull him off. The shame is that debate and questions are good for any group, as is new blood to keep things fresh, but insane dribble is just insane dribble.
The topic has been locked.
- guitargeek
11 Jan 2013 17:01You should build that, let us know how it works.donthaveakawman wrote: I guess the best thing is to find a smaller exhaust pipe, from my calculations I would need roughly .5" inside diameter exhaust pipe for sufficient torque at 7500 rpm
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- donthaveakawman
11 Jan 2013 18:30ok, so then I need a 5/8" baffle to prevent my exhaust valves from blowing out the muffler.wireman wrote:My many years in the trades tells me .5" i.d tubing is the same size as 1/2" black pipe used for gas piping into a furnace once its been reduced way down,your number is closer to 5/8 actually.donthaveakawman wrote: my magic 8 ball sources tell me 7500 rpm x 45 cubic inches รท 554,177 = .6" squared
The exhaust on my snow blower is the same as 3/4" gas pipe if that tells you anything.
Time for new batteries in your crystal ball,or you need to quit relying on the google search button to get your info
- Powerstroke_fan
11 Jan 2013 19:04
I just feel sorry for the old kaw
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
The following user(s) said Thank You: guitargeek, wireman, Street Fighter LTD, lushbaugh
- donthaveakawman
15 Jan 2013 22:13
I don't know about disconnecting the clean air system, but those reed valves are noisy. tap,tap,tap, and letting off the throttle i.e. letting it snap shut pow,pow,pow,
- donthaveakawman
15 Jan 2013 22:15 - 15 Jan 2013 22:18about the only thing I could really use seafoam for is a carbureted v8 from the 1960's or 70's. it is much easier to just dump a can in the carburetor and see if it dies or not. with late intake manifolds and dumping it in the brake booster hose it is really only going to treat one or two cylinders. I am cautious about rubber intake boots because that stuff eats gasket sealer, and probably rubber also.
Last edit: 15 Jan 2013 22:18 by donthaveakawman. Reason: more details
- donthaveakawman
15 Jan 2013 22:20
possible to dump it in the clean air valve with the engine off and hook a vacuum cleaner to the exhaust to open the reed valves, but some of the valves will be open.
- DoubleDub
- wireman
16 Jan 2013 00:21
Dump it in the gas tank and ride it off a bridge you action figure stunt double! :laugh:
- donthaveakawman
16 Jan 2013 02:33
puts the lotion on the skin, whatever. how many times do I have to replace my gaskets?
- lushbaugh
- everybodys a pro......
16 Jan 2013 03:07
um due to use of seafoam... you shouldnt need to if there fine before they will be after
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- DoubleDub
16 Jan 2013 16:43donthaveakawman wrote: puts the lotion on the skin, whatever. how many times do I have to replace my gaskets?
8, or they won't seal properly.
