exhaust valves crappy what how to clean them
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
09 Jan 2013 01:12
#566474
exhaust valves are caked with white or black sut, depending which one. what are some opinions that are best suitable for cleaning them with the exhaust off and the engine still assembled?
pretty sure the cause is the carb vacuum slides are sticking due to the needle holder jet or secondary main jet holder.
The topic has been locked.
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
Re: exhaust valves crappy what how to clean them
09 Jan 2013 01:17
#566477
put it back together and seafoam the hell out of it and ride. just regularly use it like once a month. it works.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • wireman
  • wireman's Avatar
09 Jan 2013 01:18
#566478
Dump the v8 size can of sea foam in the tank and ride the wheels off of it! B)
  • donthaveakawman
09 Jan 2013 01:35 - 09 Jan 2013 01:45
#566482
Attachment 005.jpg not found
Attachment 007.jpg not found
Attachment 006.jpg not found
that is not what I asked.
Last edit: 09 Jan 2013 01:45 by donthaveakawman.
  • lushbaugh
09 Jan 2013 01:42
#566484
donthaveakawman wrote: that is not what I asked.
without pulling your head to clean carbon deposits that is the best way. if you were to pull your head theres many solvents and methods to clean valves, if you try to use a tool of any kind in there thru the exhaust port the crud is gonna fall into the chamber to some extent. so its all or nothing really, pull the head or seafoam in my opinion. just advice. worth every penny of what ya paid for it.
  • donthaveakawman
09 Jan 2013 01:50
#566487
I have attatched some photos and am starting with a brush and marvel mystery oil. I would have to be nuts to go out on a day like today, which I did and I almost got blown off the road with the wind.
Attachment mrbikeypoo.jpg not found
Attachment valve.jpg not found
  • donthaveakawman
09 Jan 2013 01:56
#566488
I really can't seem to find anything else to take pictures of, I don't care what your opinion is. and I'm 38 years old, live in my monther's basement and post nonsense that nobody cares about on the internet all day long none stop.
  • lushbaugh
09 Jan 2013 02:06
#566490
donthaveakawman wrote: I really can't seem to find anything else to take pictures of, I don't care what your opinion is. and I'm 38 years old, live in my monther's basement and post nonsense that nobody cares about on the internet all day long none stop.
chill out im trying to help you, i see what your talking about and using the seafoam and fogging the motor while revving it will clear that crud out, its too hard and crusty to try to scrub out. just trust me and put it back together and pour seafoam in the gas and squirt it in the carbs while you rev it, youll see stuff coming out the exhaust as it dissolves.
  • wireman
  • wireman's Avatar
09 Jan 2013 02:19
#566491
Alright you want to know how to clean it with the exhaust off?
Take a soda blaster and blow that carbon off the valves/ports.
Will it hurt the motor?
Well maybe,but that's not what you asked B)
  • bountyhunter
  • bountyhunter's Avatar
09 Jan 2013 03:40
#566497
Not that anybody asked, but that buildup is normal. I wish mine were that clean. If you really want to see a bunch of carbon crud, you should see whats on the inside surfaces of the valve faces and head.
What cleans it: the machine shop drops the head into something affectionately known as a "hot tank" which is filled with bubbling heated chemicals..... and you will notice nobody putting their hand in there. :ohmy:
If the valves are free you can soak them in Chemdip and take a stiff nylon brush to them.
The following user(s) said Thank You: Motor Head
  • donthaveakawman
09 Jan 2013 03:41
#566498
Thanks for being the only computer nerds available to answer my question.
  • donthaveakawman
09 Jan 2013 04:34
#566501
I don't even know how anybody would take the time to sea foam one of these things. ;)
