newbie needing help with engine rebuild.
  • pauleaston
  • pauleaston's Avatar Topic Author
Re: newbie needing help with engine rebuild.
01 Jan 2013 02:28
#565372
I was thinking I could just use the sprockets from my existing cams for the gpz cams. They arent interchangable?
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
01 Jan 2013 02:31
#565373
very nice, if you decide you want some 28 pumpers pm me when your ready, also i like how clean your keeping everything
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • pauleaston
01 Jan 2013 17:08
#565453
I've been looking through the gallery and really like the extended swingarm. What models can I swap a swingarm from?
  • Kraz1
  • Kraz1's Avatar
01 Jan 2013 17:25
#565456
pauleaston wrote: They arent interchangable?
No sir unfortunately not, your cams would normally be a 3 bolt pattern.
  • lushbaugh
01 Jan 2013 17:28
#565457
the easiest other than a purpose built arm is the gs 1100 which is two inches over, it requires small shims on both sides of the pivot and two small shock mounts welded on. prolly the cheapest way to go, also you may need a longer brake hanger and line, if your interested use the search its been done to death. best of luck
  • pauleaston
07 Jan 2013 22:15
#566280
Attachment IMG_0496.JPG not found
Attachment IMG_0497.JPG not found
Attachment IMG_0498.JPG not found
I've begun the rebuild. While I wait for all of m parts to show up, I decided to paint my engine. I choose to use Duplicolour Engine paint. It was readily available and most people seemed to have good success with it. So I sandblasted the engine case and painted it gloss black. Looks good right now. Time and A few miles will tell the tale of how good a product it is.
  • Kraz1
  • Kraz1's Avatar
08 Jan 2013 00:53
#566312
You're doin' a Helluva job Paul... :laugh: You're scaring these guys Paul... ;) You have 42 replies, and 3439 views on your thread.
That paint will toughen up after a few heat cycles. But as you said, it's readily available... so touching it up won't be a problem.
good luck
