newbie needing help with engine rebuild.
- pauleaston
Re: newbie needing help with engine rebuild.
26 Dec 2012 00:29
That sounds like a plan. Going to order the parts this week. I'll try to document my progress as I rebuild it.
- pauleaston
26 Dec 2012 00:34
Would the 365 cams or the 395 cams be better?
- wireman
26 Dec 2012 00:52
With another wise stock motor Id go with the .365s
- Kraz1
26 Dec 2012 17:09
Back to you on the GPz Cams.... They are .375 Lift so finding a set of those from 1983-1985 would be half the price of new, and there would be no Break-In time required like with a new set of Cams.
- Nebr_Rex
27 Dec 2012 02:04Kraz1 wrote:pauleaston wrote: How much lift does the gpz1100 cams have?
I believe they are .365 Lift but I'll get back to you with a solid number.
Also if you find 28mm Pumper carburetors for your bike, swap the Needles from your 26's which are adjustable, into the 28's which are not adjustable.
All the vm28s for the '79 -'80 KZ1000E that I've seen were adjustable.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kraz1
27 Dec 2012 02:12Nebr_Rex wrote: All the vm28s for the '79 -'80 KZ1000E that I've seen were adjustable.
Unfortunately the Last 2 sets of 79-80 Pumper Carbs we've cleaned and Jetted, required installation of the Adjustable Needles from 2 sets of Non-Pumper 26's we have laying around.
- fordtruck
27 Dec 2012 12:38
Unfortunately the Last 2 sets of 79-80 Pumper Carbs we've cleaned and Jetted, required installation of the Adjustable Needles from 2 sets of Non-Pumper 26's we have laying around.[/quote]
Same here. I have a set of VM28's off a 1980. They didn't have adjustable needles so I pulled the needles out of my 77 VM26's and put in them.
'77 KZ1000-MTC 1075 kit. Stage 1 port
- lushbaugh
- everybodys a pro......
27 Dec 2012 16:09
did you get 28 pumpers yet?
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- pauleaston
27 Dec 2012 17:04
Not yet. I have Gpz 1100 cams ordered. New rings and a gasket set. . Haven't taken the valves out of the head yet. So im not sure if i need to order anything for the valves. Not sure If I'm gonna get the 28mm's yet. But I've been looking. I might just freshen up the 26mm's if I don't find something suitable.
- Motor Head
27 Dec 2012 17:19
May want to upgrade the valve springs, as the part # from Kawasaki for the stock motor and the GPZ is different for the valve springs. The motor will Want to rev higher, up to you to when to shift/ stop revving. APE has springs, which I put in mine doing the same GPZ cams.
- Kraz1
28 Dec 2012 00:23
The GPz Cams will be 2 Bolt Hyvo Chain for the Cam Sprockets. So you'll need a set of Sprockets for the Roller Type Chain to adapt.
CLICK
> ACS900K-2B
CLICK
> ACS900K-2B
- pauleaston
01 Jan 2013 02:25Attachment IMG_0495.JPG not found
Here is a little update on my progress. I've ordered the gpz1000 cams, cam bearings, valves,valve seals, heavier valve springs, dyna ignition, gaskets and seals, and piston rings. While I wait for parts, I am cleaning and painting the frame, rims, calipers, tank and side covers, and polishing whatever needs polishing. HAHA! cant stop now.
