newbie needing help with engine rebuild.
22 Dec 2012 16:08 #564089 by pauleaston
newbie needing help with engine rebuild. was created by pauleaston
My first post! I have a 76 kz900 ltd that I found a couple years ago all piled up in a corner of a gravel pit(very sad picture) and asked the owner if I could have it. Since that day I have spent alot of time and money working on it. Mostly brakes,suspension, electrical, and carb work. I ran it last summer and put 1000 mi on it. But it doesnt pull like I think it should, and it doesnt idle well either. Ive buggered with the carbs and removed the existing pods and found a stock air box for it. Still not running as well as I want. So recently I yanked the engine out of the frame and started tearing it down. So far I discovered the intake cam lobes are under spec and the valves and pistons are loaded with flakes and large carbon deposits. I havent removed the valves yet ( need to get a spring compression tool.
My question: What do you suggest I do now? Should I upgrade my cams? I want good power but I want a stable, reliable ride. i have a stock bike. But i would be willing to spend some money for better performance but I'm not looking to build a drag bike. Just looking for best bang for my buck. any suggestions will be helpful.
  • wireman
22 Dec 2012 16:23 #564093 by wireman
Replied by wireman on topic newbie needing help with engine rebuild.
Welcome to z-jungle.
A small set of drop in cams would be a good wakeup for a solid motor,Id go through rest of motor and check everything else while youre in there though B)
22 Dec 2012 21:36 #564150 by pauleaston
Replied by pauleaston on topic newbie needing help with engine rebuild.
Where is the best place to find (or order) drop in cams? Which Cams would provide the best performance? Z1enterprises doesn't seem to sell them and I'd rather not gamble with ebay.
Attachment IMG_0471.JPG not found
  • wireman
22 Dec 2012 21:42 #564152 by wireman
www.dynoman.net
They've got some .365 web cams that would help wake it up for ya B)
22 Dec 2012 22:12 #564159 by les holt
Replied by les holt on topic newbie needing help with engine rebuild.
I see your serious, Nice clean layout you have pictured. A mild set of drop ends or even the stock cams are not bad, way under rated! Just a nice tidy well running engine is pretty stout.
Les
23 Dec 2012 02:43 #564191 by Kraz1
Replied by Kraz1 on topic newbie needing help with engine rebuild.
pauleaston wrote:
My question: Just looking for best bang for my buck. any suggestions will be helpful.
I would check the bore see if it's in spec, and if so hone it and Re-Ring it with these for $99.80
CLICK
> Rings
Then I'd send my head here for a freshen up.
CLICK
> LCR
And I'd find a set of GPz1100 Cams 1983-1984 to drop-in like these.
23 Dec 2012 16:26 #564291 by pauleaston
That sounds like a plan. Would a carb upgrade be worth it as well? since I have to sink money into it anyways, I might as well do it right, right? How much lift does the gpz1100 cams have?
  • wireman
23 Dec 2012 16:51 #564292 by wireman
A stock set of 28s off a 79-80 1000 would give you a cheap good running upgrade B)
23 Dec 2012 20:06 #564332 by Kraz1
pauleaston wrote: How much lift does the gpz1100 cams have?
I believe they are .365 Lift but I'll get back to you with a solid number.
Also if you find 28mm Pumper carburetors for your bike, swap the Needles from your 26's which are adjustable, into the 28's which are not adjustable.
  • wireman
23 Dec 2012 20:29 #564343 by wireman
Is there a tach drive on the 83-84 gpz cams? B)
  • 4TheKZ1000
  • Visitor
23 Dec 2012 20:32 - 23 Dec 2012 20:39 #564344 by 4TheKZ1000
Replied by 4TheKZ1000 on topic newbie needing help with engine rebuild.
wireman wrote: Is there a tach drive on the 83-84 gpz cams? B)
No tach drive.....electronic sender
Last edit: 23 Dec 2012 20:39 by 4TheKZ1000.
23 Dec 2012 20:35 #564345 by Kraz1
No.... And for future reference, when the bike is bouncing off of the Dyna Rev Limiter.... It's time to shift son.
