Newly rebuilt KZ1000P engine will not rev...
- roman_dog
02 Dec 2012 21:17
Hey all, here's a conundrum for the masses, because I'm stumped. I just tore down a 1990 KZ1000P engine, inspected everything, and a had a machine shop do the big stuff (valves, cylinders, head, ect). Its been reassembled and started, but will stumble if revved up at all. The idle sounds like crap too. All the common things have been checked, double and triple checked: ignition, cam timing, advancer, compression, carbs. I wanted to run pods but am willing to use the airbox to make the carbs happy (they are CV). Also did a leakdown test and all the seals are near perfect. I'm fairly mechanically savvy, but I'm at a loss here so if any of you guys rebuild motors for a living your wisdom would be appreciated. I have videos if anybody would like them. Thanks in advance!
Ain't nothin' to it but to do it.
- TomW
- Keep the blue side up.
Re: Newly rebuilt KZ1000P engine will not rev...
02 Dec 2012 21:37 - 02 Dec 2012 21:39roman_dog wrote: Hey all, here's a conundrum for the masses, because I'm stumped. I just tore down a 1990 KZ1000P engine, inspected everything, and a had a machine shop do the big stuff (valves, cylinders, head, ect). Its been reassembled and started, but will stumble if revved up at all. The idle sounds like crap too. All the common things have been checked, double and triple checked: ignition, cam timing, advancer, compression, carbs. I wanted to run pods but am willing to use the airbox to make the carbs happy (they are CV). Also did a leakdown test and all the seals are near perfect. I'm fairly mechanically savvy, but I'm at a loss here so if any of you guys rebuild motors for a living your wisdom would be appreciated. I have videos if anybody would like them. Thanks in advance!
We love pictures. I dont know how to post a video, I think you need to post a link to youtube or something like that.
Down to bizniz. Did you put the air box and cleaner on? The CV carbs need the vacuum signal to work. You didn't mention valve clearances, are those right?
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Last edit: 02 Dec 2012 21:39 by TomW.
- etbike3135
02 Dec 2012 21:40
Im thinking carbs too. Did they work before the rebuild or did you do anything to them?
1973 Kawasaki Z1
18 years in dragbikes
- roman_dog
02 Dec 2012 21:57
etbike - The bike ran when I got it, not great mind you, but I think a tune would have helped it. I did completely disassemble and clean the carbs, several times, but all the stock bits and pieces are there. Haven't messed with the jets yet.
TomW - I did put the airbox and filter back on, didn't make any difference. I was hoping that would be the fix too. Even physically lifting the slides yielded no change to the stumble. Valve clearances are within spec. They're on the low side of the tolerance, but still within it.
Here are two videos I've posted on youtube:
Let me know if you need anything specific.
- baldy110
02 Dec 2012 23:26
Can you get it to rev up with the choke on?
- Nebr_Rex
02 Dec 2012 23:33
Carb boots?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- P21
02 Dec 2012 23:34
do you have the sparkplug wires right?
Kawasaki KZ 1000 Police (2002) P21
- roman_dog
03 Dec 2012 03:04
Baldy - Nope. Same stumble even with the enrichener on.
Nebr - Brand new carb boot sealed to the head with that liquid gasket stuff. No leaks there.
P21 - Plug wires are oriented right. They're all new, as are the plugs. Voltages and resistances all check out too.
Patton - Thanks for the diagram. I've noticed you posted that on many carb related threads and I actually cleaned mine per those instructions. No dice though.
03 Dec 2012 03:34Just confirming that the pilot jet "plugs" are fitted.roman_dog wrote: ...did completely disassemble and clean the carbs, several times, but all the stock bits and pieces are there....
03 Dec 2012 03:48Are carb fuel levels within specs as shown by the clear tube test?roman_dog wrote: ...1990 KZ1000P...will stumble if revved up at all....
- wireman
03 Dec 2012 03:54
Spray some starter fluid in the airbox/carbs while its running and see if it revs up
