Turning the pollution cap into a crankcase vent
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
Re: Turning the pollution cap into a crankcase vent
21 Nov 2012 10:40
#559421
thanks for the pics zed .
  • donthaveakawman
  • donthaveakawman's Avatar
21 Nov 2012 20:59
#559514
so what you are saying is to reroute the intake to the exhaust from the airbox to the crankcase vent?
  • kzz1king
  • kzz1king's Avatar
22 Nov 2012 12:29
#559618
I thought I already asked this but do not see it. Does additional venting from the bottom end negate having to vent the top end? I Vented through fill plug on mine with no problems.
Wayne
Home built KZ1000 turbo setup
22 Nov 2012 15:18
#559628
kzz1king wrote: I thought I already asked this but do not see it. Does additional venting from the bottom end negate having to vent the top end? I Vented through fill plug on mine with no problems.
Wayne
Am thinking there's no separate venting for the bottom end and top end, because they're connected by the cam chain tunnel between the crankcase and cam area.
Good Fortune! :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Nov 2012 00:09
#559682
Wayne
Yes. where u vent is not that important, .just find a spot that is the least likely to spu oil.
i think mother kaw hfound a good spot, it just need to be bigger.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kzz1king
  • kzz1king's Avatar
23 Nov 2012 00:28
#559689
Wayne
I modified a oil fill cap with a small mechanical baffle and a 1/2 inch nipple. Does not spit anything out. Have to pull hose off to remove cap but not a biggie.
Wayne
  • wireman
  • wireman's Avatar
23 Nov 2012 00:30
#559690
Picture? B)
  • kzz1king
  • kzz1king's Avatar
23 Nov 2012 00:32
#559691
wireman wrote: Picture? B)
I will pull the cap tomorrow and take a pic if you promise not to laugh :cheer:
Wayne
  • wireman
  • wireman's Avatar
23 Nov 2012 00:42
#559694
At the same time like Ive said before if you have to start adding lots of extra venting just to keep oil from blowing out of a motor its time to do a leak down test to make sure youre not just blowing everything past worn rings or a worn bore.
On a high rpm racing engine thats spinning its way down the track at 10,000 rpms its understandable that things getting stirred up internally pretty violently,but on the typical street bike thats just being jumped on once in a while its not such a big issue.
If youve got a streetbike thats blowing gaskets out to vent itself and the stock crankcase vent isnt clogged up youve got internal issues and the extra venting is just a band aid. B)
  • wireman
  • wireman's Avatar
23 Nov 2012 00:43
#559695
Wayne
As long as it gets the job done! :laugh:
  • kzz1king
  • kzz1king's Avatar
23 Nov 2012 00:57 - 23 Nov 2012 01:00
#559698
double
Last edit: 23 Nov 2012 01:00 by kzz1king.
  • kzz1king
  • kzz1king's Avatar
23 Nov 2012 00:57
#559699
Attachment Picture175.jpg not found
Attachment Picture180.jpg not found
