Weird noises, hard start after overheating
Re: Weird noises, hard start after overheating
18 Oct 2012 19:30
#554553
After starting a cold engine and allowing it to run a few seconds, can spray water mist onto all the header pipes.
The spray is supposed to sizzle and instantly vaporize when there's combustion inside the cylinder.
If water droplets run down the pipe, there's failure of combustion in the cylinder.
Use the water spray :cheer: -- don't touch the pipes with your hand or fingers. :pinch:
Good Fortune! :)
  • strobel5
  • strobel5's Avatar Topic Author
18 Oct 2012 19:48
#554556
Hmm ok ill try it, but that doesnt explain the knocking, does it?
1978 kz650d(SR)
  • gengomerpyle
  • gengomerpyle's Avatar
18 Oct 2012 20:00
#554559
have you pulled the plugs to see how they look?
strobel5 wrote: Yeah I mean I did a pipe test the day it overheated and 1/4 were hotter than 2/3 but 2/3 did have heat . Also it seemed to be running well until it got really hot.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
18 Oct 2012 20:12
#554565
With regard to just checking on some basics after the rebuild, is it for sure that the F mark aligns with the case mark at idle rpm?
Good Fortune! :)
18 Oct 2012 20:18
#554568
When first started after the rebuild and first began riding it around breaking it in, did everything seem normal, and without any unusual noises?
How long did the normalcy continue, and under what riding conditions?
Good Fortune! :)
  • strobel5
18 Oct 2012 20:39
#554579
It was running like normal,I took it on some quick 10 min runs, not going over 5k rpm. everything felt smooth and responsive, no weird noises besides a little cam chain noise. Then the day it broke down was the longest run probably 20 min, was running it a little harder. Had about 30 miles on it after rebuild. As far as checking spark plugs it was lean on 1/4 and rich on 2/3 which I thought might be the problem. I crudely timed it,seemed to run fine so didnt worry too much, dont have the tools to time it perfect, was going to take it to a shop to sync the carbs and check timing.
1978 kz650d(SR)
  • strobel5
18 Oct 2012 20:42
#554581
In hindsight I should of got the timing down perfect before riding too much, but it was really running great and I was ready to ride!
1978 kz650d(SR)
18 Oct 2012 21:09
#554588
:unsure: "Points" ignition?
Good Fortune! :)
  • strobel5
18 Oct 2012 21:15
#554591
I gapped the points to .035mm and tried my best to use my crappy multimeter to check the continuity if thats what you mean?
1978 kz650d(SR)
18 Oct 2012 21:28 - 18 Oct 2012 21:33
#554592
Setting timing "statically" aka "static method" (engine not running) should get pretty close.
First set the gap, and then adjust the timing to where the left-hand (9 o'clock) points just begin to open as the F mark for 1/4 aligns with the case mark.
The "dynamic" timing (engine running) is more accurate, using a timing light, and whereby the advancer function may also be viewed.
Would also assure there being fat blue sparks on every plug when the engine is spun over with the plugs removed and held grounded against the engine.
Good Fortune! :)
Last edit: 18 Oct 2012 21:33 by Patton.
  • strobel5
18 Oct 2012 22:38
#554597
So I did the spray test and 2/3 the water is running down the pipe so is the timing off?
1978 kz650d(SR)
  • strobel5
18 Oct 2012 23:57
#554605
also if I do a coil check, I swap the coil leads and the spark wires correct?
1978 kz650d(SR)
