Weird noises, hard start after overheating
- strobel5
18 Oct 2012 15:11 #554514
by strobel5
1978 kz650d(SR)
Weird noises, hard start after overheating was created by strobel5
So I finished rebuilding my engine on the bike, I had been riding it around breaking it in. Yesterday I was riding it and it started to bogg down and then it died, couldnt get it started, let it cool down until and had to up the idle just to get it home. Checked the spark plugs and 1/4 lean and 2/3 rich. Today I went to start it just to see how it sounded and then I got these weird noises. They sound pretty bad . Im attaching a video of the noises hopefully yall can help me pinpoint what it is.
1978 kz650d(SR)
- Roadflyer
- Thank you received: 13
18 Oct 2012 16:13 #554526
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic Weird noises, hard start after overheating
Do a compression test and hope for the best.
- gengomerpyle
- Thank you received: 17
18 Oct 2012 16:19 #554528
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic Weird noises, hard start after overheating
maybe a bearing
1982 GPZ750R1 ELR
1971 Honda CB750K
- Del_Herring
- Thank you received: 29
18 Oct 2012 16:35 #554530
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic Weird noises, hard start after overheating
the clacking/knocking sound kinda sounds like a bearing to me, but a little faster than I've heard before. Maybe just because bikes tend to idle higher than cars. Might pull the valve cover and double check all the valves good, messed up valve spring could cause one to get bent and make noise and run poorly. It's always a little hard to tell just from a video. But the bearing or valves are my best guess.
Not sure about the kazoo sounding noise when you start, but mine does that too, so if that's a different thing I'd love to know.
- strobel5
18 Oct 2012 17:21 #554532
by strobel5
1978 kz650d(SR)
Replied by strobel5 on topic Weird noises, hard start after overheating
Yeah I was hoping not to hear its a bearing but thats what I figured, I was worried about the kazoo noise but I guess thats kinda normal, sounds like its coming from the starter area. I will do I compression test and let yall know. Just sucks, thought I actually rebuilt it right and was all proud and now this lol.
1978 kz650d(SR)
- Del_Herring
18 Oct 2012 17:31 #554534
by Del_Herring
Yea, I saw on the duplicate of this thread MFOLKS said that weird sound was the starter clutch. That's not a big issue I don't think. The bearing sound probably is. Good luck man, and hey, you at least got it running, so most of it's probably fine, just gonna be some work to fix the one thing you missed the first go around. We all gotta learn somehow man.
- strobel5
18 Oct 2012 18:02 #554536
by strobel5
1978 kz650d(SR)
thanks for the encouragement, I did a compression check numbers came out as: 1:130 2:125 3:120 4:135. This is quite different from my first check after rebuild which was: 1:155 2:150 3:125 4:175. Did ring seating change it that much? Also it is running better now, Sounds like the noise is coming from the starter clutch/sprocket cover area of the engine. Once again I am attaching a video trying to get the idea of the sound. Could it be the start or starter clutch or am I just having wishful thinking?
1978 kz650d(SR)
- bountyhunter
- Thank you received: 337
18 Oct 2012 18:33 - 18 Oct 2012 18:35 #554538
by bountyhunter
Replied by bountyhunter on topic Weird noises, hard start after overheating
The SQUORK noise when you hit the starter made me think it was the starter clutch.
Other thing to check is timing chain tensioner.
I would also want to check oil pressure.
Last edit: 18 Oct 2012 18:35 by bountyhunter.
- strobel5
18 Oct 2012 18:45 #554539
by strobel5
1978 kz650d(SR)
how would i go about checking oil pressure?
1978 kz650d(SR)
- Thank you received: 2829
18 Oct 2012 19:10 #554545
by 650ed
Replied by 650ed on topic Weird noises, hard start after overheating
Are you positive all 4 cylinders are firing? Ed
- gengomerpyle
18 Oct 2012 19:27 #554550
by gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
when you rebuilt the motor did you use pre lube on the bearings and rings?
1982 GPZ750R1 ELR
1971 Honda CB750K
- strobel5
18 Oct 2012 19:28 #554551
by strobel5
1978 kz650d(SR)
Yeah I mean I did a pipe test the day it overheated and 1/4 were hotter than 2/3 but 2/3 did have heat . Also it seemed to be running well until it got really hot.
1978 kz650d(SR)
